20 Most Recent
Maytag HAV2558 Top Load Washer Questions & Answers
Makes spueking sound when washing ok when
your break is slipping over time the break makes the metal plate that stops the tub have a smooth groove in it. This is what causing the squeak. The plate could need sanded a little bit to give the break some grip but unfortunately you need a special tool to take off the break. It is pressurized by a spring. If you try to take it off without the tool you could get really hurt. Eventually you will probably have to get it fixed because it wont grip at all then it wont agitate properly. But for now it wont hurt anything to run it if you can ignore the noise
My washer fills with water and then hums and wont
Thanks for choosing FixYa and welcome to the site. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya
The water fills up, but during the clean cycle it
The inlet works and the wash begins but the water level sensor must work to shut the water inlet. Does this happen? If so when the motor stops check if the voltage to motor stops. If so the program controller is faulty.
Howeever is there is voltage and motor heats up , then check the capacitor or maybe a weak winding of the motor.
Tub will not spin and
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
The inner tub moves slightly while the agitator is
This is an indicator that the helical-drive/brake package assembly needs servicing.
At this point in the machine's life, it is best to have the transmission evaluated, snubber pads replaced, and the brake package competently serviced by a Maytag Tech.
This is a complete disassembly process wherein several special tools are required to disassemble and reassemble the machine.
Maytag top load performa, put
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Maytag MVW7232HW0 top load, error codes and condensation on control panel when using hot watet
1. ERROR CODES: CHECK THE USER MANUAL FOR THE WASHER TO IDENTIFY THE SPECIFIC ERROR CODES BEING DISPLAYED. THIS WILL HELP YOU PINPOINT THE ISSUE AND TAKE APPROPRIATE ACTION, SUCH AS RESETING THE WASHER OR CONTACTING CUSTOMER SUPPORT.
2. CONDENSATION ON CONTROL PANEL: IF YOU'RE EXPERIENCING CONDENSATION ON THE CONTROL PANEL, IT COULD BE DUE TO THE HOT WATER TEMPERATURE OR THE HUMIDITY LEVEL IN THE ROOM. TRY USING WARM WATER INSTEAD OF HOT WATER TO SEE IF THAT REDUCES THE CONDENSATION. YOU CAN ALSO TRY INCREASING VENTILATION IN THE ROOM TO HELP DISPERSE THE MOISTURE.
