20 Most Recent Maytag Neptune FAV6800AW Top Load Washer Questions & Answers
Drain the water off then try again then check your foilter
Maytag Neptune... | Answered on Jan 10, 2018
In my opinion it would be better to download a service manual from the manufactures website to quench your frustration for a small price eric
Maytag Neptune... | Answered on Dec 27, 2017
Maytag's service center emailed me back saying that I needed to purchase a magnet for the right side of the lid, even after I sent them photos of the lid. There is no magnet on the right side, so don't be fooled! The lid comes apart fairly easily. First, with a screwdriver, apply a little downward pressure and pry out the center liquid/powder holder. It is hinged on the bottom and will come right out. Next, pull out on the bottom corners and the lid liner will come straight down. Now you can verify that the magnet (on the left side!) is there and seated correctly. If that is the case, go ahead and reassemble. Unplug the washer. Lift up the top portion of the washer (at the crease). You may need a screwdriver to pry up on it. I didn't. I just pulled up on it. It comes up fairly easily. Now you can see the locks, mounted with one bolt on either side. Inspect the wiring for any wear or damage. Next, remove the locks one at a time, unhook the wire connector and plug them back in. Reassemble. Leave the lid up (not sure if it matters, but I did) and plug the washer back in. That's all I did and it worked! The "od" alarm didn't come back.
Maytag Neptune... | Answered on Nov 28, 2017
Check that the spigot where the Air Dome connects is also clean, it may be full of gunk so the dome gets no water/air pressure...
Maytag Neptune... | Answered on Oct 03, 2017
No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller.
Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage.
LID SWITCH TEST- next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,
basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer
http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
By the way my advice is free cuz God is good!
Diagnosing and Repairing Spin and Agitate Problems in Whirlpool Kenmore...
Maytag Neptune... | Answered on Mar 24, 2017
The washer is trying to go into spin but failing. The two sprag clutches are probably sticking, This usually indicates a water leak.
The seal should be replaced. The bearing and sprag clutches should also be checked and will probably need to be relubricate or replaced.
Maytag Neptune... | Answered on Jul 06, 2016
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Maytag Neptune... | Answered on Jun 25, 2016
Maytag Neptune FAV6800AW Top Load Washer Logo
1,827 questions posted
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
maytag neptune fav6800aww washer drum
  • Washing Machines
