20 Most Recent
Canon L120 Fax Laser Printer Questions & Answers
LOUD SOUND WHEN SENDING FAX
There are 4 volume controls to access them press MENU.
You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
Now use the up & down arrows to get to
Buzzer Volume = that the machine beeps
SET
Key volume = the tone that sounds when you press keys on the control pad
SET
Alarm volume = the alarm if something happens.
SET
Line volume = sets the level you hear at the fax is actively transferring a fax.
If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
Dirty print on printed or incoming fax
I think is a cartridge problem, try to change it.
It's possible the drum to be worn. For a precise response, i need a picture with an printed page.
All the best !
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
How do i receive a
under user mode, choose data registration, report settings and under TX report set YES. Then after each fax you get transmission report with image of document you've sent.
Memory is full. How do I print RX and then delete
Hope this helps.
1.) Press (system monitor) until <Fax Monitor> is displayed.
2.) Press - or + to select <2.TX/RX Transmission)->Press [set]
3.) Use the numeric buttons to select the transmission numbers of the fax job you want to delete-->Press [set]
4.) If you want to delete the fax job press [-] for <YES>
Regards
