20 Most Recent
Maytag MDG2600BWW Gas Dryer Questions & Answers
Dryer spins,screen clean,exhaust open blows good
Check the coils on valve or the igniter. Access both thru Access panel on lower right of front panel. Set heated dry cycle & start, igniter should glow bright followed by a "Click" sound, which is valve opening. If it glows and no click, replace the valve coils (2 donut looking objects on top of valve). If no glow, replace igniter, usually just unplug to remove, carefully, they are ceramic and break easy.
8/6/2014 1:39:49 AM •
Maytag...
Answered
on Aug 06, 2014
Why my Maytag gas dryer
will not shut off
1.defective timer--replace timer motor or switches as needed
9/23/2011 4:50:44 PM •
Maytag...
Answered
on Sep 23, 2011
My Maytag DG410 dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The
Dryer is not TurningDryer Repair - The
dryer will not startheatman101
8/13/2011 11:47:59 PM •
Maytag...
Answered
on Aug 13, 2011
My Maytag Gas Dryer runs and starts to heat, but
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101./,,./
8/13/2011 12:21:23 AM •
Maytag...
Answered
on Aug 13, 2011
Not heating up
gas no heat tip....
check outthis
heatman101
6/12/2011 2:04:28 AM •
Maytag...
Answered
on Jun 12, 2011
My Maytag gas dryer won't heat. I have replaced
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
1/15/2011 4:04:04 AM •
Maytag...
Answered
on Jan 15, 2011
No heat while drying
sounds like your glow plug ignition has failed, or last but not least your control board has failed,
but 90% of the time it the glow rod
12/19/2010 4:19:08 PM •
Maytag...
Answered
on Dec 19, 2010
Dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
12/13/2010 4:19:40 AM •
Maytag...
Answered
on Dec 13, 2010
When dryer is turned on
gas no heat tip....
check out this
heatman101
sggh
9/30/2010 11:47:59 PM •
Maytag...
Answered
on Sep 30, 2010
The Dryer is not producing any heat to dry the
gas no heat tip....
check out this
heatman101
9/18/2010 1:59:36 PM •
Maytag...
Answered
on Sep 18, 2010
