If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
58 questions posted
1,743 Questions
867 Questions
815 Questions
489 Questions
196 Questions
