20 Most Recent
Maytag MGS5770 Gas Kitchen Range Questions & Answers
Maytag stove MGS5770ADB - Burners will not light - ignators
The spark module should be behind the rear panel of the range, or behind the bottom drawer, mounted on the interior back wall. If you go to searspartsdirect.com, the part is listed as item number 22 under the "Gas Controls" heading. The part number is 74004283. Just type in your model number and follow the links on the next page. There are helpful drawings to assist you. If in doubt, trace the wires from the the surface igniters and they all will lead back to the spark module. I hope this information helps you. Let me know if you need further assistance.
Oven flash f-3.
F3 is a failure in the oven sensor circuit. That circuit being from the ERC outlet pin to the harness, to the sensor and back to the ERC return pin. Could be a bad sensor that is failing under heat conditions, or possibly a connection that is failing as the unit heats and it expands. The temp of the sensor at room temp is 1050-1100 0hms and goes up 100 ohms for every 50 degrees from there. If you can get it to fail, and ohm it out, you will know for sure. I will tell you a sensor is a heck of a lot cheaper then an ERC and is more likely the culprit. Here is the sensor to order.
Self Cleaning Codes
F1-E5 - Calibration Shifted - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).Here is the part to order.The part comes with a 365 day, any part, any reason return policy.
Location of the spark module
Most time it is on the back side under a shield
Move a shield and you will find it
This stove has these sealed burners:
Give em a twist and lift these puppys out like this:
If it ain't on the back then remove the bottom drawer and it will be under a shield in there. Hard to tell on the
diagram If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
