20 Most Recent Maytag MSD2734GE Side by Side Refrigerator Questions & Answers
My freezer works fine, however my fridge is not cold.
Is there ice build up in the freezer? Ours does this we have to remove the bottom & above draw & bang the back plate until the ice built up behind it breaks off & falls down onto a tea towel & then you hear the fan start whirring again, it sounds brutal so wrap your hand in a spare tea towel, but bash away till the ice comes out & fan whir's again, as this fan circulates the cold air into maintaining fridge temperature ?? That's the only way ours then chills fridge again, so much for frost free fridge freezers eh! ??
12/30/2017 10:19:43 PM • Maytag MSD2734GE... • Answered on Dec 30, 2017
We just had a new RO Unit installed at our sink, and a line run to our Maytag fridge. The water filter is inside, at the top. We don't really need the filter anymore, as the RO water is more tha
Take the filter to the hardware store and get the necessary fittings (and maybe a short piece of tubing) to connect the in and out lines without the filter. Perhaps easier deal is a new filter which should NEVER become clogged on RO water.
8/3/2017 2:55:30 AM • Maytag MSD2734GE... • Answered on Aug 03, 2017
2answers
The ice cube maker heating element doesn't seem to work very well. Many time ice has stuck in the unit and i need a blow dryer to get it to release it. I need to do this almost once a week
Corry unfortunately about the only and best way to fix that is to replace the ice maker itself the parts are expensive if you like but it's just not worth it to rebuild it that's my opinion ice maker click here=> http://www.repairclinic.com/PartDetail/Ice-Maker-Assembly/D7824706Q/915772?replacedManufacturerPartNumber=61005508?RCAID=35836 Ice Maker Assembly D7824706Q
8/31/2016 1:56:19 AM • Maytag MSD2734GE... • Answered on Aug 31, 2016
0answers
0answers
Msd2142ar
Be the first to answer 7/11/2013 3:46:44 AM • Maytag MSD2734GE... • Posted on Jul 11, 2013Be the first to answer
Maytag side by side water leak
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
9/24/2011 3:09:14 PM • Maytag MSD2734GE... • Answered on Sep 24, 2011
0answers
I have a Maytag MSD2142ar
replacement globes not working. are there fuses
8/26/2011 6:17:45 AM • Maytag MSD2734GE... • Answered on Aug 26, 2011
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
8/22/2011 2:00:01 AM • Maytag MSD2734GE... • Answered on Aug 22, 2011
Maytag MSD2734GE My freezer isn't producing
Look inside the freezer and see if there is a layer of frost covering the rear panel of freezer. If yes then unplug and begin manual defrost.The most likely problem is possibly the=> 61005988 Adaptive Defrost Control found here=> MSD2734GEQ Control Panel part 13 is the Adaptive Defrost
here is the=> 61006199 Defrost Heater and location HERE
When you click on heater below there is a movie that will show you how to test, if you have other questions or problems please let me know, Thanks, Sea Breeze
4/28/2011 3:48:21 AM • Maytag MSD2734GE... • Answered on Apr 28, 2011
My Maytag side by side
We have the same issue on our Maytag Side by Side - MSD2734GE. Empty the freezer. At the back of the freezer are two panels in the back. It is only necessary to remove 3 screws. The first 2 screws hold on the very bottom panel. Remove the back panels and look at the drain located at the bottom. You will notice a thin piece of metal covering a drain hole. Remove the screw holding the metal in place. Then remove the ice build up around the drain hole.
9/18/2010 5:35:12 PM • Maytag MSD2734GE... • Answered on Sep 18, 2010
Maytag PTB21BBGRB problem with refrigerator being
First look into rear of freezer on backwall for a layer of frost. If you find frost then the next step is to check the defrost timer found inside fresh food section Click here=> PTB21BBGRB Control Panel part #12 in large view is the defrost timer. There maybe a plastic plug below the control panel that you may pry away for you to manulally turn slowly clockwise until it clicks and the defrost will take place. If that works the the defrost timer part number is Click Here=> 68233-3 or here=> www.pcappliancerepair.com
that also offers solutions to their customers. On some service manuals contact Appliance911seabreeze.com If that does not work fo you then please let me know so we move to the next step. Thanks Sea Breeze
8/12/2010 4:04:06 PM • Maytag MSD2734GE... • Answered on Aug 12, 2010
Hums every 5 seconds
try to understand it!
4/14/2010 2:57:24 AM • Maytag MSD2734GE... • Answered on Apr 14, 2010
Ice forming in freezer
make sure the door is sealing completely...if its letting air in ice will form
11/7/2009 12:09:52 AM • Maytag MSD2734GE... • Answered on Nov 07, 2009
The inside bottom portion of my freezer is filling
check defrost drain tube
8/9/2009 10:14:55 PM • Maytag MSD2734GE... • Answered on Aug 09, 2009
check in the freezer side and look at the back wall and see if there is any build up of frost, your coil may be block, so no air flowing through the coil, your unit may not defrosting, you need to check the defrost heater,the defrost timer or the defrost thermostat one of these part can be defective
5/5/2009 1:32:17 AM • Maytag MSD2734GE... • Answered on May 05, 2009
Fridge not cold...freezer is ok.
Hi and welcome to FixYa,
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
Good luck and Thank you for using FixYa. Happy Holidays.
12/11/2008 3:52:05 AM • Maytag MSD2734GE... • Answered on Dec 11, 2008
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
Maytag MSD2734GE Side by Side Refrigerator Logo
26 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
ice cube maker heating element doesnt
  • Refrigerators
