20 Most Recent
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Questions & Answers
Thesis problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
7/5/2019 7:15:42 AM •
NetGear...
Answered
on Jul 05, 2019
Cant connect my reliance broadband
I think you might be getting confused.
When it tells you it is static ip it might be referring to your isp connection. I recommend calling reliance broadband and asking them for help with setting up your router . Ask for their support area.
DHCP you might be thinking of could be for your local area network.
By ringing your ISP they will be able to guide you through manually setting up your router and they will know what settings are needed .
5/15/2018 11:30:20 PM •
NetGear...
Answered
on May 15, 2018
Lost my wireless connection on laptop and wireless
There are many reasons you could loose a connection from a laptop to a router, without giving any information on the model of your laptop, router, wireless setup (Password etc...) it is somewhat impossible to give you an answer.
3/4/2015 7:34:09 AM •
NetGear...
Answered
on Mar 04, 2015
How do i get my netgear wireless password
just simply log into netgear page by entering 192.168.1.1 and enter it asks u to enter user id and password, by default user id will be admin and password is password after that u get get netgear log in page in left pane u will find a wireless settings in that u can find ur wireless password that's it
3/2/2015 10:04:41 AM •
NetGear...
Answered
on Mar 02, 2015
How do I turn netgear on>
If there is a lock symbol that means the wifi is password protected. if you are the owner and forgot your wifi password, you have to reset the router.
if you are in a cafe, please ask the staff if they can let you have access.
10/22/2014 1:55:44 PM •
NetGear...
Answered
on Oct 22, 2014
Can not find WPA number to connect with internet a PS3
This is a cut and paste but it saves me time typing.
Find the Netgear router's WPA code on its setup page. Access the setup page by typing "192.168.0.1" into your Web browser's address bar and pressing "Enter." If that number doesn't work, try "192.168.1.1" instead. Type "admin" as the username and provide your router's password. Use "password" if you haven't set a custom password. Click "Wireless Settings" at the left side of the setup page and read the WPA code from the passphrase box on the page.
4/18/2014 5:06:10 PM •
NetGear...
Answered
on Apr 18, 2014
Key for VT4
If you were to Google this and look for a key ,Google will more than likely find one for you.Caution be careful here ,when doing searches like this you are routed to various sites so make sure you have a good virus protection on before you go to these sites.Also look for key codes or key generators and make sure it is for your version ,check your help on the program and it will generally give you the version number as many games have updates and they only apply to a specific version.
4/18/2014 3:15:29 PM •
NetGear...
Answered
on Apr 18, 2014
I want to connect my cell phone to my wireless router
There is little point in posting a question with no real information.
Saying something is "broke", "doesn't work", "can't connect" or that you "need" or "want something" is pointless without ALL the information.
What actual products are you using? Makes, models, connections...everything about your problem is necessary. We are not there with you. We cannot see what is obvious to you. Most problems occur when you try to get something to work with something else. We need to know all the things you are using and doing that ends with your issue.
The issue is the last thing we need not the only thing.
4/4/2014 7:54:21 AM •
NetGear...
Answered
on Apr 04, 2014
