20 Most Recent
Samsung SyncMaster 940MW 19" LCD Monitor Questions & Answers
940mw vertical sync instability
Try another monitor to be sure it is the monitor not the computer. If it is the monitor you need to take it to the repair shop. Be sure you are operating it in the proper range.
3/7/2015 8:22:08 PM •
Samsung...
Answered
on Mar 07, 2015
Won't turn on no power
You more than likely have bad capastors or diodes that will require taking the monitor apart then the parts replaced they will have to be soldered in and a small solder gun will be needed to keep heat as low as possible so the board doesn't get damaged. Use only japanese made gold rated parts
3/18/2014 12:40:01 PM •
Samsung...
Answered
on Mar 18, 2014
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
1/9/2014 2:07:02 PM •
Samsung...
Answered
on Jan 09, 2014
Pc screen will not come on
HI,Check you power port.Check it Power Cable.If Monitor not open then may be monitor damage. If PC ask then SMPS check it. Because all power supply to SMPS. Next to check it mother board power come or not. Then RAM slot check, and checking carefully. One time all power section and connector disconnect and some time wait and again proper way connect all device. May be solved you problem.Thanks..
10/10/2013 4:43:19 PM •
Samsung...
Answered
on Oct 10, 2013
Ive had my samsung 940mw
monitor led didn't light mean power cable is damaged or monitor you can try
good luck
1/8/2012 5:02:42 PM •
Samsung...
Answered
on Jan 08, 2012
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
11/5/2011 8:28:04 PM •
Samsung...
Answered
on Nov 05, 2011
