20 Most Recent
Siemens WTXD5300US Electric Dryer Questions & Answers
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
2/11/2014 1:56:10 AM •
Siemens...
Answered
on Feb 11, 2014
No heat while running.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
9/10/2011 3:52:46 AM •
Siemens...
Answered
on Sep 10, 2011
My siemens electric dryer will not start a cycle.
One is a thermal limiter that operates the heating element and the other is a moisture sensor.
Check to see that the door switch is operating properly with an ohmmeter (with the power disconnected, of course).
2/21/2011 2:00:09 AM •
Siemens...
Answered
on Feb 21, 2011
Siemens dryer has a extra swishing sound like
Is your dryer new?
if its isn't then probably that its ball bearings inside is started to end its service life or the belt begins to deteriorate and the drum touches the housing.
if its new, then probably that there is something getting loose inside or some foreign objects get inside the drum (e.g. moneys, pens, etc.).
12/29/2010 6:12:14 AM •
Siemens...
Answered
on Dec 29, 2010
