20 Most Recent Philips HTS3541/F7 - 5.1-Channel Blu-ray Home Theater System with Questions & Answers
Go to the main menu and try and find the factory reset. That should restore all the changed settings to before you messed around with it.
Philips... | Answered on Dec 11, 2019
Unlock code for Philips HTS3541
1. Press Home
2. Press on R/C 8 6 8 9 3 1 0 (the 0 being multi-region)
Philips... | Answered on Nov 14, 2018
not set up properly would be my first guess .
Philips... | Answered on Mar 18, 2015
Check the wiring. If there is a break in the wire they will not play. Also check where they connect to the back of the device.
Philips... | Answered on Mar 13, 2015
I think if you try a CD disc, you will find that disc will play. The Optical Pickup(laser) has worn out of specification. There are actually 3 lasers in the unit; a CD, DVD and Blu Ray lasers. They are all use different wavelengths of light, so one laser cannot cover all 3 wavelengths. Unfortunately, you will need a new pickup. Again, try the CD. I'm 90% sure it will play fine, unless the pickup is covered in dust(like my house :-(. If you would like more information, or would like to inquire about having your Philips repaired, please visit my website at audioserviceclinic.com. Thank you.
Philips... | Answered on Dec 30, 2014
For a printed manual you should contact your vendor.
Manuals in PDF file format for the system can be downloaded here:
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=HTS3541/F7&hlt=Link_UserManuals&mid=Link_UserManuals&scy=CA&slg=AEN
Philips... | Answered on May 04, 2014
Look up the program called playon. I have been using it for 3 years and its pretty good. You need at least a high DSL speed, cable modem is great. You also need a decent computer, although I bought a acer notebook from walmart for $250 as a dedicated playon server and it worked well. And finally you need a DNLA compatible player to connect to your tv. Some TVs have this built in if it is able to be put on the home network. PS3 ,360, Wii are all able to fine DNLA servers on the network. Sony made a bluray that was also able to find DNLA servers and that is what I use. However the new PS4 I've read is not DNLA capable, so newer sony bluray may not also. Basically playon collectes videos from free sites and logs them. You pull up the playon server on the TV with whatever device you are using to connect it to the tv. Now just scroll through the all of them until you get what you are looking for, click and it plays.
Philips... | Answered on Mar 27, 2014
Brand New? Send it back !
First go step by step through the instructions to make sure you hooked it up right.
Still not work? Return for exchange or refund!
Philips... | Answered on Dec 04, 2013
Make sure the input you are trying to use, is switched to analog and not digital. For more information, please visit my website at audioserviceclinic.com. Thank you.
Philips... | Answered on Nov 30, 2013
It would all depend on which type of connection you are using. HDMI, Coaxial and Optical, are all digital outputs/inputs and not analog. Make sure you have switched whatever input you are using to analog or digital, whichever is appropriate. For more information, please visit my website at audioserviceclinic.com. Thank you.
Philips HTS3541/F7 - 5.1-Channel Blu-ray Home Theater System with Logo
Popular Tags
36 questions posted
Top Philips Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
unlock region philips hts 3541 f7
  • Audio Players & Recorders
