20 Most Recent Symbol MC9060-G Portable Terminal Questions & Answers
Hallo. I need to update Symbol MC9060, because it
Where can you find the update? I can't find the right update for our device.
9/27/2013 9:45:56 AM • Symbol MC9060-G... • Answered on Sep 27, 2013
MC9060
you can currently use wep or wpa(tkip)
7/4/2012 2:14:09 AM • Symbol MC9060-G... • Answered on Jul 04, 2012
I am here to help with any mobile computer needs
Thanks Kganoe. Is possible to replace the scanning sound for a diferent .wab file? diferent .wab file for diferent kind of barcode (lenght)????
2/19/2011 8:40:08 PM • Symbol MC9060-G... • Answered on Feb 19, 2011
0answers
I've replaced the motherboard for MC9060-G mono
Hello fanida. I would bet that the problem lies with the motherboard. MC9060s come in both color and mono screens (as I'm sure you know). Check the part number of your new motherboard against the old one. If they're different, I would bet that the new motherboard was made for a color screen model. If this is the case, just get a motherboard that supports a monochrome screen, or you can get a color screen and use it in that model. I hope this helps. Good luck!
1/6/2010 3:50:32 AM • Symbol MC9060-G... • Answered on Jan 06, 2010
Well it seems that there is some mistake while you replace the screen of your terminal, may be some loosen wire or any shorting in the wires, so first of all please check the wires again that they connect properly or not. Can you please tell us how do you connect the new screen in your terminal?
Thanks
12/21/2009 6:12:59 PM • Symbol MC9060-G... • Answered on Dec 21, 2009
MC9060 Symbol how to configure
Please give me a call I can deffinatley help...678-468-9242 - Lyndon
10/20/2009 6:31:12 PM • Symbol MC9060-G... • Answered on Oct 20, 2009
2answers
Symbol MC9060G
cold boot the unit, 1/2 eject the battery press the trigger and push the power button. this will do a full cold boot on the unit but you will not loose your software.
2/26/2009 2:11:33 AM • Symbol MC9060-G... • Answered on Feb 26, 2009
Scanners turn on automatically
How old are those battery's? The below is copyed from http://www.batteryuniversity.com Aging is a concern with most lithium-ion batteries and many manufacturers remain silent about this issue. Some capacity deterioration is noticeable after one year, whether the battery is in use or not. The battery frequently fails after two or three years. It should be noted that other chemistries also have age-related degenerative effects. This is especially true for nickel-metal-hydride if exposed to high ambient temperatures. At the same time, lithium-ion packs are known to have served for five years in some applications. Manufacturers are constantly improving lithium-ion. New and enhanced chemical combinations are introduced every six months or so. With such rapid progress, it is difficult to assess how well the revised battery will age. Storage in a cool place slows the aging process of lithium-ion (and other chemistries). Manufacturers recommend storage temperatures of 15°C (59°F). In addition, the battery should be partially charged during storage. The manufacturer recommends a 40% charge. Hope this helps
9/22/2007 10:11:18 PM • Symbol MC9060-G... • Answered on Sep 22, 2007
What the IE symbol in Isuzu meter board?
'Internet Explorer' probably has a problem. Use Chrome or Firefox.
3/9/2024 3:45:01 AM • Symbol Computers... • Answered on Mar 09, 2024
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
  1. Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
  2. Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
  3. Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
  4. Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
3/3/2023 10:16:08 PM • Symbol Computers... • Answered on Mar 03, 2023
2answers
How to type degree symbol on mac
There are a few different ways to type the degree
  1. Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
  2. Use the character viewer:
  • Go to the Edit menu and select Emoji & Symbols.
  • In the search field, type "degree".
  • Double-click the degree symbol to insert it into your document.
  1. Use the ASCII code:
  • Press and hold the Option key and the Shift key.
  • Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
1/6/2023 8:09:59 PM • Symbol Computers... • Answered on Jan 06, 2023
2answers
British Gas T4 RF My battery symbol is flashing. Do I need to change the battery?
no info generic answer --have battery and alternator tested--check belts and connections
1/5/2023 8:41:08 PM • Symbol Computers... • Answered on Jan 05, 2023
Videocon ac remote not working
Hi, Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included. You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
7/27/2022 11:25:03 PM • Symbol Computers... • Answered on Jul 27, 2022
How do I get firmware or a plugin for Zebra Symbol LS4278 Scanner - Model LS4278-SR20157ZZWR
Use " Scanner update utility " to update the firmware. after this try to configure scanner with " 123 scan utility " https://www.zebra.com/us/en/support-downloads/scanners/general-purpose-scanners/ls4278.html#pageandfilelist_895c
5/20/2022 10:41:28 AM • Symbol Computers... • Answered on May 20, 2022
Symbol MC9060-G Portable Terminal Logo
15 questions posted
Popular Products
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
mc9060 symbol configure
  • Computers & Internet
