20 Most Recent
Toshiba Portege M400 PPM40U01000E Tablet PC Questions & Answers
Where sim card position in m400
Only a select few (very few) M400's have a 3G wireless module, and from what I understand they do not use a Sim Card as they use CDMA technology. You can tell if your unit has the 3G unit with several different ways.
A. Check the device Manager
B. Try and install the 3G power management driver, and see if it loads.
C. Check using Toshiba Utilities if installed
D. This is the hardest way, but the best. Remove the keyboard, and if the 3G unit is installed, it will be at the top right hand side of the case under plastic film. (I have had three M400's, including the top of the range one that I am writing this on, and I have never seen a 3G unit).
If you do have the 3G unit installed, look for an ESN number. You should then be able to then call Verizon and have the service activated.
G-Luck
My portege M400 wont start
I have the M400 and it also does this. I don't know much about computers, but I found out when you apply a little pressure to the left of the touchpad and beneath the keyboard as you're flipping on the power slider, it boots up much more often. I know... sounds crazy and stupid, but it works for mine and it's been doing it for almost a whole year now. It doesn't work everytime, but whenever the light flashes and the fan cranks up to a million RPM i just pull the battery out
Pen
in what way can't you use it? does it turn on ?
How do I disable the M400 biometric finger print
uninstall the Protector" Suite (finger print scanner software ) and restart it and check .....
if its not happening try in bois..... restart your laptop hit F1. then navigate to the integrated devices, there will be an option to enable or disable the finger print scanner there.
My m400 wont start at all, just an orange light
have you had any power surges lately?
Try taking the battery out of the laptop and starting just on power.
if this doesnt help then take battery and power and leave laptop for few hours then try again on only power or battery.
Let us know how it goes.
Remove password bios toshiba portege m400 please!
Here is a guide toremove windows passwordwith Windows Password Recovery Tool Professional from http://www.windowspasswordsrecovery.com/Step1: Download and install Windows Password Recovery Tool.Step2: Burn CD/DVD/USB Flash Drive. (Namely it is to burn a Windows password reset disk.)Step3: Set the target computer boot from CD/DVD or USB.Step4:
Remove the forgotten Windows passwordwith the burned CD/DVD/USB. Then log on to Windows without a password.Of course, you can also finish
Windows password remover if you have a password reset disk in advance. That's also an easy solution.
Source: http://www.windowspasswordsrecovery.com/windows-password-remover.htm
I have a Toshiba Portege
Turn the sensitivity down in the sound mixer?
Right hand mouse click on the loudspeaker icon and choose recording mixer. Adjust as required.
Hope that helps.
Toshiba M400 tablet wont start
hello jpmca
try to take off your fan cable
here http://slashstar.com/blogs/alex/archive/2006/09/30/Toshiba-M400-Fan-Hack.aspx
and try to release the memory sodimm, release the battery and plugin the power cord again
if problem solve try to updated your bios for fan noise solution
here
http://support.toshiba-tro.de/kb0/TSB6A01KJ0000R01.htm
oke
cropp
I have install win 7
Go to the Toshiba Mobile support web site for you exact model. Select Drivers download. Select Windows 7 32bits or 64 bit and download the latest versions of all that relate to the Tablet module, and that includes the Wacom driver.
If you Windows is genuine you can uninstall all the Wacom drivers then execute the Check new hardware wizard ( of Hardware changes) or even Windows Update
