20 Most Recent
Depo Auto Parts Saturn L100 L200 LW200 L300-1 2001 2002 2003 2004 A/C Condenser Cooling Fan Assy w/ blades, motor, & shroud OEM: TYC 610640, Interchange : GM3113115, Other : 15867597 Questions & Answers
How to tell if fuel line is frozen starter turns but doesnt crank engine
in extremely cold weather, you may need an engine block heater or lighter weight oil. you can verify that the gas is flowing if you disconnect the main gas line to the injector/carberator, attempt crank, and see whether fuel squirts out or not. if its cold enough to freeze gasoline, it could be cold enough to freeze oil, anyway
My 2001 Saturn Lw200 fuel pump fuse blows, and
Sounds like the wire is touching somewhere against the bodyCheck the harness under vehicle by the gastank, unplug it and test for fuse blowing. Test input to tank for dead short.Some vehicles have a removeable plate under back seat for accessing this area. Most you would have to lower the gas tank being careful not to break fuel lines and an impact will be necessary to remove bolts and if these break a threaded rod with washers may be necessary by poking a hole through the floor to attach strap back onto it. Support gas-tank with a jack with board on it. Hopefully not too much gas as it's heavy stuff if you have to drop the tank to replace fuel pump.Some places try to sell you a 3 or 400.00 unit when all can be taken apart and replaced with a good pump and not the sending unit included. just make sure is for the right size engine.I suspect that a wire is shorting out somewhere, typically where it exits the vehicle to the fuel tank or under the Power Distribution Unit which is where the fuses and relays are under the hood, typically near the battery.Some vehcicles the ECM or Computer moves around and the harness gets frayed or shorted near it against the body of thecar but us-ually within 2 feet of the ECM itself.Youtube can give yuou more details
Cant find the knock sensor in my 2001 Saturn
Just a guess but is typically on top of intake manifold and may have to remove down to intake to access it but should be able to accesss the wires to test it's ohm value.Youtube may help you more.
2001 Saturn still will not start, after changing
are you sure your fuel pump is pumping ...how to see is have someone in the vehicle to turn that key on on your wave of the hand ,,,you want no noise ...open your gas cap and put your ear beside the hole ...if you hear it hum for a few seconds your fuel pump is installed ,,If not you have a new bad fuel pump ..That is the problem that I can say I am 100% sure ..let me know please and God Bless
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
