If you are seeing an ice sheet at the bottom of
the freezer, your drain is blocked. When the unit goes into defrost, the
moisture will fall into a drain that runs under the unit to a pan where it
evaporates. If the drain becomes blocked, each time the unit defrosts, it adds
a layer of ice. I have seen them several inches thick. Pull out
the bottom bins in the freezer and look for some screws
that hold the rear panel in place. Take them out and pull the panel out of the freezer section.
At the bottom of all the ice you will find a small drain
hole. It may take a hair dryer and/or some warm water to melt your way through,
but get it all melted away (you will fill up the drain under the unit and it
will start to overflow so have towels handy) and make sure water is running
down the drain. When it is all cleared out, you should be ok, but check it
again in about 12 hours and see if you have any buildup.
On your maytag refrigerator ,Take the back side off, which is located in the interior part of the freezer. When you get in there, there are coils, and under the coils is the drain that is supposibly clogged.Defrost that hole with hair dryer an warn water.Water should not be over hot, otherwise plastic parts will get melted.A basic Luke warm water.Unplug the refrigerator from power outlet, while doing this.---------
Once you take the panel off the back of the freezer cabin, you will see that there is a lot of ice both on and under the thin metal "funnel" to the drain. There will be some gunk in there too.You needed to slowly and carefully clear all that ice formed and dirt.------
Getting this drain hole cleaned will help.But if its again n again getting collected then its defrost problem.The defrost board needs to be replaced.-----------
You can get required parts from from online sites like: ---
www.repairclinic.com or from searspartsdirect online site. --------- This
should help.Thanks.Helpmech.
41 questions posted
822 Questions
518 Questions
315 Questions
239 Questions
