20 Most Recent
Xerox Phaser 7400/DXF Laser Printer Questions & Answers
Xerox Phaser 7400DN keeps rejecting jobs I send
It's hard to set up the mpt tray when the display is out. Send the job to the printer with no paper in the mpt. The printer should then ask you to put 11 x 17 in the mpt. Hope that helps.
Error code 929
Pls check the Wast toner full. or not and check wast duct assembly,
that assembly spring was damaged, pls replace duct assebly and change new wast toner,
Error u60
code u60: Job offset home position sensor does not detect home position for the Job Offset Assembly.check home possition sensor actuator home posiition sensor sns harness ... is there any damage or misalignment. replace broken parts. if that did not help Test the job offset home position sensor. run the service diagnostics offset home position test. Does the sensor function correctly? If yes you well have to replace the engine control board. That will give you that error. Hope this helps if you need more help let us know at iteminconline. iteminconline
Error message: cyan imaging unit is either missing or unseated
The problem is with the top cover assembly. It could be a few things. I would first try the toner sensor flags(the magnet may not be strong enough to read properly). Also replace the toner cartidge because it's magnet may also have gotten weak. Third, I would try the Toner sensor board.
I have had this problem with many printers and normally it is just the flags because of the weak magnets.
How do you empty the waste cartridge on the phaser
it's a simple you respect clean inside of the waste reservoir by a solvent nettoyant with water for twice Remarque : le non-respect de ce mode d'
emploi/des consignes de sécurité peut entraîner une mise en danger
