20 Most Recent Maytag CWG3100A Gas Single Oven Questions & Answers
My gas oven heats very slowly and sporadically.
Good morning, your oven most likely has a weak igniter. That would keep the gas safety valve from opening properly. It will get close to the required amperage but valve will only flutter and not allow enough gas to ignite. Hope that helps.
2/11/2018 4:46:14 PM • Maytag CWG3100A... • Answered on Feb 11, 2018
7answers
F9 error
hi there,
can you tell me the model # on your stove please?
11/29/2014 3:58:24 PM • Maytag CWG3100A... • Answered on Nov 29, 2014
I just turned on our pilotless oven and noticed the smell of gas. Turned it off naturally. The stove worked fine earlier in the day.
Hi, You could have a weak ignitor which can cause a smell of gas, I would have it checked unless you have a way to test for amperage. Test with amp probe should read 3.2 -3.6 amps if less than 3.0 replace ignitor. I hope this helps. Good Luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
8/10/2014 3:57:48 PM • Maytag CWG3100A... • Answered on Aug 10, 2014
2answers
Hadle broke on one sid of oven door, How do you
You need to remove the door before you start dismantling the door. It is labor intensive and to hard to explain but here is a diagram that shows you the break down. Here is a video to point you in the general direction for the repair.
8/3/2014 1:21:51 PM • Maytag CWG3100A... • Answered on Aug 03, 2014
How to change the light bulb in a maytag 8114P732-60 oven
Hi Mary. I had a bad bulb in my Maytag new from the factory. I also had a hard time getting the glass lense cover off, and didn't want to be too rough with it for fear of breaking it. But it WILL come off if you turn it hard enough. I've since seen suggestions about putting warm water on it to loosen it up. And another person wrote and said using an oil filter wrench on it worked like a charm. Good luck
8/3/2014 1:08:25 PM • Maytag CWG3100A... • Answered on Aug 03, 2014
0answers
0answers
Maytag 5750ADW oven problem
No you do not have the correct board most parts retailers will not accept a return for an installed part
1/30/2014 11:18:02 PM • Maytag CWG3100A... • Answered on Jan 30, 2014
The top come on but the oven will not light any more
you'll need a glow starter (it works same as an pilot) or something like that, you can get to it from the back, check resistance and most likely they are bad.
1/23/2014 7:54:33 PM • Maytag CWG3100A... • Answered on Jan 23, 2014
0answers
Emits black smoke that stains wall and ceiling
Somethin's burning.Get a gasfitter to check air/fuel ratio and, well, clean the oven...
10/18/2013 1:57:23 PM • Maytag CWG3100A... • Answered on Oct 18, 2013
Nat. gas to lp conversion
Your LP provider should have all the necessary components to make it work.
3/6/2013 9:34:53 PM • Maytag CWG3100A... • Answered on Mar 06, 2013
Starters will not stop clicking
That is usually a sign that the spark module has gone out and needs replacing. This is only if the clicking continues after all the burners are in the off position If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
5/28/2012 6:58:01 AM • Maytag CWG3100A... • Answered on May 28, 2012
Oven light stays on constantly
you have a stuck light switch, either at the door or on the control panel. either will most likely need to remove the oven at least part way. then a test of the door switch will tell you if that is bad or not.
2/4/2012 5:05:15 PM • Maytag CWG3100A... • Answered on Feb 04, 2012
Clock and oven control seemed to be shorted out when cord singed from being put to close to oven body.
it may have burned up all of the small circuit boards in this gas oven , I wouldunplug it then open it up to see what is burned and also replace the cord first ,get back to me after you open it and see what you have , only do this if you are able to work on circuits or cords replaced
12/26/2011 1:47:22 AM • Maytag CWG3100A... • Answered on Dec 26, 2011
Burners will not light
check the igniter switch on back of stove might have gone bad. Also make sure your stove did not get unplugged by accident. no electricity no spark
11/22/2011 10:44:46 PM • Maytag CWG3100A... • Answered on Nov 22, 2011
Maytag CWG3100A Gas Single Oven Logo
185 questions posted
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
hadle broke one sid oven door
  • Ovens
