20 Most Recent
LG LSC091PMA Split System Air Conditioner Questions & Answers
How to fix LG error code ch 23
there is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
HOW TO REMOVE FRONT PANEL TO CLEAN MY FILTERS ?
Is the problem not enough air or strong air flow that is warm? It may be much more than the filter. look at the air handler (fan unit). the filter should be at the end where the air enters the unit.
How to fix LG error code CH 23?
There is a problem with a sensor ,but it must to change both(because are 2 senzor )even is broken just one.this senzors are locate in outside unit.
My LG unit cannot start.
Switch of the power. Lift front cover and unscrew seating cover and remove it. Remove your PCB and check where there is a 1.5mg fuse is there. Check for continuity. If not replace and check for loose wiring to find why the fuse blown. Thanks.
My LG airconditioner keeps on
sounds like the filter needs to be removed and cleaned. it should be easily removable from the front. after you have done this reset it either by removing power for about ten minutes or there should be a reset button right on the control panel
Thermal shutdown
Its getting hot for a reason and its not suppose to do that. Sounds like they are saying the compressor is getting thermally hot and shutting down? hAVE YOU CLEAN THE CONDESNOR COIL ON THE OUTSIDE? yOU CAN TAKE A HAIR BRUSH AND GO UP AND DOWN ON THE COIL TO CLEAN IT AND USE A WATER HOSE TO WASH OUT THE DIRT. tHEN ON YOUR AIRHANDLER IN THE HOUSE CHECK YOUR EVAPARTOR COIL AND SEE IF IT DIRTY AND CLEAN IT WITH THE BRUSH AND GO UP AND DOWN ON THE COIL AND CLEAN IT YOU CAN USE A SQURT BOTTLE OF WATER TO CLEAN IT. nEXT CHECK YOUR BLOWER FAN THE SQUIRREL CAGE TO MAKE SURE ITS CLEAN. AND IF NOT CLEAN IT. iF THIS DOES NOT CURE IT THEN IT IS A PRESSURE PROBLEM WTH THE FREON.
Had a Fujita Split System installed by a
Sometimes you have to do what I call "Overkill" to cure this problem..The leak detector should find it, unless it is in the unit itself. Typically, the leak will be at a connection. Many of the new systems come precharged, and the linesets are installed with fittings. You could vacuum the system then change the linesets to copper and sweat the joints, eliminating a fitting issue with the linesets. If that doesn't cure, then the leak is withing the system and possibly a warranty issue. Good Luck! I hope you find this to be very helpful!
Blowing hot air
check the contactor that powers the compressor for 240 volts a.c. and make sure you have 24 volts a.c. to energize the contactor from the thermostat inside the building,you can check both these voltages from the contactor
Smells like something has died in my lg split
No joke, something probably did die in there. I have found rats in the drain pan or caught up in the fanmotor. Check this first. Second you can pour in some Miltons (solution used for washing baby bottles) or a mild mix of pool chlorine and water, directly into the drainpan. If you open the front cover, this is the plastic collection pan directly below the aluminium fins where the condensate water drips into. The chlorine will sanitize this area and should help remove the smell. But you should check and remove whatever died there in the first place.
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
