20 Most Recent LG 42PX4DV 42 in. EDTV-Ready Plasma Television Questions & Answers
2answers
Plasma 42inch TV
As you may have guessed by now, the breakdown is likely being caused by a bad connection or ground. May need resoldering unless it is a semiconductor breaking down. If you can find a service center that services LG (low grade) products, I would take it there for repair. You have probably noticed a lot of heat escaping from the top of the unit after it has been on awhile. That is a big problem with plasma TV's as heat is the biggest destroyer of electronic parts that I know of (well after lightening storms). A temporary solution would be to install some fans blowing air up from the bottom back of the unit to allow it to play longer before getting too hot. Or watch less TV
8/20/2014 11:31:43 AM • LG 42PX4DV 42... • Answered on Aug 20, 2014
Zashto nemoga da gledam di tv
Hi Anonymous Please give more descriptive information in english and we can try to assist you. Kind regards
8/15/2014 6:17:57 AM • LG 42PX4DV 42... • Answered on Aug 15, 2014
3answers
LG 42PX4DV - HDMI Audio / PC Audio IN problem
I found the fix. Had the same problem.I right clicked on the sound speaker icon in the bottom right of Windows 7.Chose Playback Devices.Once this window opens, then make sure you are on the Playback tab.Scroll down until you see the HDMI Device. (Mine was hidden at the bottom of the list.)Then choose "set as default".The sound will begin playing on the TV with only the HDMI connected......no need for an extra audio cable.
7/14/2013 5:58:28 AM • LG 42PX4DV 42... • Answered on Jul 14, 2013
0answers
Tv signal
Be the first to answer 5/21/2013 3:45:55 AM • LG 42PX4DV 42... • Posted on May 21, 2013Be the first to answer
0answers
Lg42pc10
Be the first to answer 7/12/2012 9:13:32 PM • LG 42PX4DV 42... • Posted on Jul 12, 2012Be the first to answer
Sanyo plasma tv shows no picture. Picture comes on and goes off. Sound come on and goes off.
check to see if your input signal is connected correctly. Might not be a tight connection.
5/25/2012 1:36:23 AM • LG 42PX4DV 42... • Answered on May 25, 2012
Screen glitters when tv gets
Only option is to install an internal fan to cool the plasma. This is caused by the extreme heat made by the plasma tvs. It is overheating.
Thank you and best of luck!
7/14/2011 6:52:14 PM • LG 42PX4DV 42... • Answered on Jul 14, 2011
0answers
2answers
I get the letters msg on the bottom of my 42inch l...
Menu, Special, Software update....2 choices Manual and auto
Put on manual and you start getting MSG at the bottom of the screen.
Put on auto and it stops.
Andy
8/31/2010 8:37:26 PM • LG 42PX4DV 42... • Answered on Aug 31, 2010
The LG 42px4dv-aa States that
Your TV is telling you that the network cable company or free air is not broadcasting their programs in HD. Just because they have didgital programming doesn't mean that it is HD programming.
8/20/2010 12:37:57 PM • LG 42PX4DV 42... • Answered on Aug 20, 2010
No audio out on hdmi with desktop
Chances are your desktop doesn't support audio through HDMI. Try to find a spec sheet for the unit you have, an upgrade may be possible
5/27/2010 8:44:04 AM • LG 42PX4DV 42... • Answered on May 27, 2010
Remote control does not work altho tested ok
There are two parts in the TV that could be causing this issue. It is either a defective IR board in the TV or defective main board. The IR sensor on the IR board picks up the signal from the TV and sends it to the main board that decodes it.
It is also possible there is a loose connection form the IR board and main board. The only way to check which of the above mention failures is causing the remote control not to work is to check the voltages along the line with a digital multimeter to match the ones in the service manual.
10/9/2009 7:59:47 AM • LG 42PX4DV 42... • Answered on Oct 09, 2009
Picture has snow
check the input cable or signal and insert it properly.
9/24/2009 7:58:56 AM • LG 42PX4DV 42... • Answered on Sep 24, 2009
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
61 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
lg 42px4dv hdmi audio pc audio in
  • Televison & Video
