20 Most Recent
LG RZ32LZ50 32 in. LCD Television Questions & Answers
The sounds cut out after 15 mins
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Is my LG 32lz50 tv hd and digital
Your tv is HDTV ready but unfortunatly it only has a NTSC tuner which is analog, you will need a set top box to recieve OTA over the air digital, if you have cable sattilite or an HD dvd player you can display HD. You only need the set top box if you use an anttenna.
Let me know if I can assist further and please rate this solution. lone99star Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/jason_77a19afa8d604dee
My lg screen RZ 32LZ50,
Hello
Contact your nearest LG authorised service center. They only can provide it to you. They won't give it to you, but will get the set repaired with new screen at their service center. OL.
When swiched on, the screen displays green vertical bands
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hi
Most likely a power supply component has aged and thus changed value and/or
failed. Take it to a reputable repair person.
SKY HD
IT should work with Sky HD because the resolution is high enough at 1366x768.
Its HD Ready
JonnieC
LG 47
This means that the bulb is bad, and is taking forever to heat up. You need to get the bulb replaced to fix it.
