20 Most Recent Konica Minolta bizhub C351 All-In-One Laser Printer Questions & Answers
Error 2703 en konica minolta bizhub 750
Directly below the drum is the transfer and separation ration unit. which houses two very, very thin gold plated wires the one on the right is the transfer wire which transfers the image off the drum on to the paper as the paper goes over the wire while the drum place the image on the paper. the second wire is separation wire which has an AC signal on it to prevent the paper from sticking to the drum. The second wire might be broken. Have it replaced best to have booth done at the same time since unit comes out? or the spring at rear of the unit are not making good electrical contacts. Ensure power is off. as they do carry High Voltage during the normal operation.
4/3/2020 5:09:16 PM • Konica Minolta... • Answered on Apr 03, 2020
Konica minolta C351 codes
Low power code fuser not warm up properly
4/16/2019 3:36:44 AM • Konica Minolta... • Answered on Apr 16, 2019
Error code C-B116, what does it mean?
Code B116 Description Communication error with the fax board An undefined communication error occurs between the controller and the fax board. Remedy 1 Check the connector CN106 on MFPB for proper connection and correct as necessary. 2 Change FAXB. 3 Change MFPB. That error means a problem with the FAX Board. Now, checking connections or re-seating connections of fax board to main board are advised first, then replacing fax board if that fails.
5/15/2018 10:39:19 PM • Konica Minolta... • Answered on May 15, 2018
Error code c-d362 in c250
Did you replace the main board if so the the small board on the main board does not match the info on the other board and you have a NV RAM error NVRAM stores the serial number counter info very important info. Need a tech to re-flash the firmware not drivers maybe a new board and NVRAM Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/25/2018 5:59:42 PM • Konica Minolta... • Answered on Mar 25, 2018
Konica minolta c350 malfunction error c0206 error
replace the black image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/18/2018 10:46:35 PM • Konica Minolta... • Answered on Mar 18, 2018
I have an error code that reads C-5353 I have tried everything and ... Konica Bizhub Password Reset We have a Konica Bizhub c350 that we ...
sorry there is no service code 5353 in the c350 your sure??? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 8:50:01 PM • Konica Minolta... • Answered on Mar 10, 2018
Code C-E002
Did you have the firmware (Copiers Operating system) NOT DRIVERS updated??????? Do this step 1. If it occurred after upgrading the Firmware, conduct the following setting. [Service Mode] ? [Sate Confirmation] ? [Memory/HDD Adj.] ? [HDD Version Up] If not do this: 2. Turn OFF the main power switch and turn it ON again, and conduct the following setting. [Service Mode] ? [System 1] ? [Initialization] ? [Data Clear]. IF not reformat the hard drive, or replace it. Worse case replace the main board$$$$$$$$$$$$$$$$$$$$$$$$ Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 6:30:54 PM • Konica Minolta... • Answered on Mar 10, 2018
Eror c 2160
replace the cyan image unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 5:14:00 PM • Konica Minolta... • Answered on Mar 10, 2018
2answers
I have a bizhub c351
you need to load the proper firmware. do you have a card that you can load the firmware onto? i can load the software on a card and send it to you if needed....
1/30/2018 5:42:35 PM • Konica Minolta... • Answered on Jan 30, 2018
2answers
ERROR C-3101
this is a fusing pressure roller code.....
The way to clear the code is by opening/closing the front door.
1/20/2018 9:40:19 AM • Konica Minolta... • Answered on Jan 20, 2018
Minolta bizhub 162 error code 32
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please perform these actions attentively.
1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
6/29/2017 3:42:57 PM • Konica Minolta... • Answered on Jun 29, 2017
How do i turn on
is this for the fax?? buy a fax kit
5/5/2017 1:19:02 PM • Konica Minolta... • Answered on May 05, 2017
2answers
HOW C3801 BIZHUB 421
Thermisters / Heat Sensors abnormality. Replace the thermisters, in order to get rid of this problem permanently.
11/12/2016 8:07:29 PM • Konica Minolta... • Answered on Nov 12, 2016
Bizhub c250 C-E002 error
C-E002 - message and method parameter failure - possible MFPB fault
10/15/2016 2:51:00 PM • Konica Minolta... • Answered on Oct 15, 2016
Double image printing in konika minolta
replace the fuser Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/9/2016 10:05:15 PM • Konica Minolta... • Answered on Jul 09, 2016
Konica minolta 163 cof32 error
replace the drum and developer Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 7:53:56 PM • Konica Minolta... • Answered on Jul 04, 2016
Recover passwork for bizhub c 351
which one Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/30/2016 11:33:35 PM • Konica Minolta... • Answered on Jun 30, 2016
C35 error code c0203
which is it c35 or c351 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/27/2016 3:41:26 AM • Konica Minolta... • Answered on Jun 27, 2016
C12c6 hard disk error
replace the hard drive Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/27/2016 3:34:53 AM • Konica Minolta... • Answered on Jun 27, 2016
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
305 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
change c352 admin password
  • Office Equipment & Supplies
