20 Most Recent Konica Minolta PagePro 1390MF All-In-One Laser Printer Questions & Answers
My Konica Minolta 1390Mf says open front cover and
Normally when you get a remove paper jam and there is no paper, it is because the paper didn't make it out of the tray. Open the front door and remove your toner/drum unit. If you look inside you will see a gray half circle roller, try cleaning this roller with mild detergent. Do not use alcohol, this will dry out the roller.
9/12/2018 4:29:41 AM • Konica Minolta... • Answered on Sep 12, 2018
Tengo 1 page pro 1390
Need a qualified tech as the firmware is on a secured server that only qualified techs have access to the Firmware is the printer OP system. Companies don't like having their copier op system given out freely. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4/1/2018 6:11:16 PM • Konica Minolta... • Answered on Apr 01, 2018
Lamp error
check this site for service manual Service manuals electronic components datasheets and equipment schematics... The problem is the scanner located under the big glass is bad it should be a very bright lamp when you make a copy Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2018 7:35:10 PM • Konica Minolta... • Answered on Mar 11, 2018
Drivers mac
6/25/2016 4:34:07 PM • Konica Minolta... • Answered on Jun 25, 2016
Lamp error
How do you know its a lamp error?. if it is the scanner lamp its located under the glass. And you replace the whole module not just the lamp, or is it the fuser lamp, you just replace the whole fuser section which is the Hot part. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/25/2016 3:47:58 PM • Konica Minolta... • Answered on Jun 25, 2016
max out at xp, but try this site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/24/2016 4:07:34 AM • Konica Minolta... • Answered on Jan 24, 2016
Error fuser temp
replace the fuser unit Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/22/2016 4:07:41 AM • Konica Minolta... • Answered on Jan 22, 2016
Can you use this printer with a mac computer
yes check this site out Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/10/2016 4:04:52 AM • Konica Minolta... • Answered on Jan 10, 2016
SERVICE CODE COF 32
which model ###### Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/29/2015 11:20:08 PM • Konica Minolta... • Answered on Dec 29, 2015
How do you reset Konica Minolta Pagepro 1490MF fuser temperature error ?
Hold down the Red key and power on. if the code comes back replace the fuser unit. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/28/2015 11:04:01 PM • Konica Minolta... • Answered on Dec 28, 2015
1380 engine panic
what is a engine panic?????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/25/2015 9:51:50 PM • Konica Minolta... • Answered on May 25, 2015
Konica minolta pagepro 1390 mf printer problems
what is the problem sir/mam? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/21/2015 1:35:24 AM • Konica Minolta... • Answered on May 21, 2015
1390 null tag error
Navigate to the site below, the steps are listed under: Advanced Computer User Solution (manual restore):
5/14/2014 11:12:01 PM • Konica Minolta... • Answered on May 14, 2014
Problem for h4 error code
It is a fuser problems check the thermistors.
3/17/2014 5:55:48 PM • Konica Minolta... • Answered on Mar 17, 2014
I need instalation software
Konicalminoltaus Minolta 130 190 f driver
6/19/2013 5:36:50 PM • Konica Minolta... • Answered on Jun 19, 2013
I want to downlodad it to apple mac
Please visitwww.onyfxtp.mykonicaminolta.com
2/15/2013 1:11:59 PM • Konica Minolta... • Answered on Feb 15, 2013
Konica Minolta PagePro 1390MF All-In-One Laser Printer Logo
70 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
PagePro Konica Minolta
  • PagePro Konica Minolta
Most Popular Question
konica minolta 1390mf driver windows7
  • Office Equipment & Supplies
