20 Most Recent Nikon D50 Digital SLR Digital Camera with 28-90mm F/3.3-5.6 Lens Questions & Answers
Every picture comes out very dark
Check your pics on the computer. Are they still dark? If they're OK then problems in camera's display.
1/25/2018 11:06:49 PM • Nikon D50... • Answered on Jan 25, 2018
I can not get the histogram to show up when viewing the display. I have doen the steps outlined in the manual but nothing!
You are looking at the single-image playback? Not thumbnails and not zoomed in? Does the display cycle through the other modes when you press cursor-up/down?
3/5/2013 8:45:10 PM • Nikon D50... • Answered on Mar 05, 2013
2answers
Nikon D50 Digital Camera. I cannot take a
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't do it, try a different card.
9/4/2010 8:31:41 PM • Nikon D50... • Answered on Sep 04, 2010
How do i take pics without the memory card in?
You don't...only point-and -shoot cameras have internal memory.
12/21/2009 2:07:58 AM • Nikon D50... • Answered on Dec 21, 2009
I cannot release the battery on Nikon D40X
Check out the videos. If the battery has swollen you will have to prise it out. https://www.google.com/search?q=release+the+battery+on+Nikon+D40X ..
2/1/2022 2:57:33 PM • Nikon D Cameras • Answered on Feb 01, 2022
2answers
Convert NEF format to JPEG
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
7/8/2021 3:19:13 AM • Nikon D Cameras • Answered on Jul 08, 2021
D3400 cannot turn on Bluetooth. Camera says cannot due to current settings/
Is the camera in airplane or power saving mode?
2/2/2019 10:40:21 PM • Nikon D Cameras • Answered on Feb 02, 2019
Need to know how to open my D-7300 to replace broken gear.
More info needed.
1/17/2019 9:59:57 PM • Nikon D Cameras • Answered on Jan 17, 2019
2answers
My 1 year old Nikon D7200 camera will not take a clear picture of Christmas lights unless I put it in mirror up position. .. why
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
8/2/2018 9:46:01 PM • Nikon D Cameras • Answered on Aug 02, 2018
Nikon D70s Back Thumb Control not working.
switch button got damage due to hard press so you need to replace it
8/24/2017 4:29:01 PM • Nikon D Cameras • Answered on Aug 24, 2017
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
7/2/2016 5:56:02 PM • Nikon D Cameras • Answered on Jul 02, 2016
Nikon Teleconverter
You could probably use either a 1.4 x or a 2 x, depending on how much you wanted to increase the focal length of your lens. A 1.4 x would give you a range of 98-420, a 2 x would give you a range of 140-600. Having said that, teleconverters are not usually recommended for use with zoom lenses, and you would lose one stop with the 1.4 x, two stops with the 2 x, thus necessitating longer exposures. Also, with the increase in focal length comes an increased probability of camera shake being more apparent, due to the increased magnification. In your position, I would attempt to get closer to the subject, using a teleconverter as a last resort if this is not possible.
6/8/2016 10:45:38 AM • Nikon D Cameras • Answered on Jun 08, 2016
My camera reads No SD card inserted...but i have
Format the SD card first.
4/17/2016 3:37:52 AM • Nikon D Cameras • Answered on Apr 17, 2016
About Nikon l510
Go to Nikon website for manual download.
3/27/2016 1:24:43 AM • Nikon D Cameras • Answered on Mar 27, 2016
My Nikon D3200 says shutter error can I fix this issue myself?
hi, did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
3/3/2016 8:38:11 PM • Nikon D Cameras • Answered on Mar 03, 2016
Aw120. How do I fix lens error?
You need send your camera to service, your zoom lens stuck.
12/4/2015 9:35:17 AM • Nikon D Cameras • Answered on Dec 04, 2015
How do I change the format of my downloaded pix from NEF to JPEG?
I use GIMP 2, a free open source editor that is very sophisticated. I think I had to install an add-on so that it would read NEF files. Gimp converts all files that are edited in it to its own "xtg" file extensions. After I finish editing, I save the picture in the "xtg" file extension then I import it in "jpg" format to the same folder where the original NEF along with the XTG formats are stored. During the editing process, I usually scale the image if I plan to send it somewhere on the web. I think a lot of other editors have a similar function, especially if the proper codecs are installed. In addition, in the past I have used conversion programs to do the same thing but it's been a long time. Do a web search for NEF converters and you may come up with a free program or two that will allow you to make the conversion without editing the picture.
10/9/2015 2:35:10 PM • Nikon D Cameras • Answered on Oct 09, 2015
Why commlite macro extension tube does not work with d5100
Not sure, but if you shoot in manual mode and use manual focus the camera should still take photos. Kind of defeats the purpose of spending money on auto focus ones though. Try to turn the top dial on the camer to M (manual) see what happens?
2/2/2015 10:15:24 AM • Nikon D Cameras • Answered on Feb 02, 2015
Raw formet copy to hard dish
To copy your pictures, jpg or NEF (RAW) to your computer, you first must install the ViewNX2 software that came with the camera (on a CD) or get the software for free from the Nikon website. Fitst install the software, then connect the camera with an USB cable then switch the camera on. Current versions of Nikon software Nikon Knowledgebase
1/11/2015 4:23:18 PM • Nikon D Cameras • Answered on Jan 11, 2015
Nikon D50 Digital SLR Digital Camera with 28-90mm F/3.3-5.6 Lens Logo
5 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
not get histogram show up when viewing
  • Cameras
