20 Most Recent Zenith Z50PX2D 50 in. Plasma HDTV Questions & Answers
2answers
I have a Z50PX2D and
5/31/2023 12:39:27 PM • Zenith Z50PX2D... • Answered on May 31, 2023
3answers
Will not power up. Tested from plug to power
The power supply board could very well be defective. I would also check the Zsus board and the Xsus boards. If either of these boards fail it could also cause the power supply board to fail.
You can unplug the connectors to the zsus board at the power supply and try to turn the set on. If it does turn on, the power supply board is ok. If not, the power supply is bad. If the power supply board is ok, undo the plug connectors that power the Xsus board and hook up the plug connectors to the Zsus board. Turn the set an and see if it stays on or shuts down. Part numbers should be on the boards. Zenith is really LG Corp. Their customer support number is 1800-243-0000.
Hope this helps,
Steve
11/2/2018 5:16:16 AM • Zenith Z50PX2D... • Answered on Nov 02, 2018
I just Bought a Zenith 50 in. plasma tv at a yard
so could using a digital desk to box converter and running through that if tv wont fire up board is damaged TV may not be worth the cost of the replacement parts
4/7/2017 12:39:50 PM • Zenith Z50PX2D... • Answered on Apr 07, 2017
3answers
Zenith Plasma TV Manual
did you try there web page?
5/29/2016 3:24:45 AM • Zenith Z50PX2D... • Answered on May 29, 2016
2answers
Screen went black on my zenith Z50PG10
Contact the authorized service center for Zenith. The main power supply board to your TV has damaged. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
10/14/2015 4:59:39 AM • Zenith Z50PX2D... • Answered on Oct 14, 2015
Which is the energy consmption
TV type ......................plasma TV Screen size ..................50 in Viewing Angle ....................160 degrees Color .......................dark silver, silver Video............. Interface Component, composite, HDMI, S-Video PC Interface ..............VGA (HD-15) Timer Functions................ Sleep, wake HDMI Ports Qty ...................1 port(s) Power Consumption Operational .................450 Watt www.electro-medical.blogspot.com
10/4/2015 12:09:44 PM • Zenith Z50PX2D... • Answered on Oct 04, 2015
It comes on but the picture is fuzzy and the dark spots stay dark for a few seconds after it goes away.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Faults & possible causes to Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5/23/2015 2:37:27 AM • Zenith Z50PX2D... • Answered on May 23, 2015
The sound on my TV goes up and down on its own
Sounds like main system control memory IC fault. Anyway, try a reset to this set first. If it do not help you, contact any service technician to replace this IC. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
2/24/2015 9:36:35 AM • Zenith Z50PX2D... • Answered on Feb 24, 2015
3answers
Zenith Z50PX2D 50" Plasma HDTV
Had similar problem; I have determined that it was the capacitors in the powerboard! I replaced the capacitors at a higher voltage, and the tv is working again (for now) :) To anyone else having issues, I highly recommend looking at the powerboard before spending any money either fixing or replacing the tv. Take the back off the TV and look at the powerboard, if any of the capacitors are blown they will be bowed out in the back (should be flat) Mine had 7 blown capacitors, all were 3300uf 10v capacitors. (Funny enough it was every single 3300 10V capacitor on the powerboard that blew out...) The fix cost me a total of $21!! And $15 of that was for both soldering and de-soldering irons. Through e-bay I got the 3300uf 16v capacitors for $6.50 (including shipping) I am hoping that the higher voltage will thwart this issue in the future, however only time will tell. If they blow again, I'm going to try 25v capacitors. wish me luck!
1/16/2015 6:36:41 PM • Zenith Z50PX2D... • Answered on Jan 16, 2015
I don't have a picture,but i do have sound.What might be the issue?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
10/11/2014 9:44:37 AM • Zenith Z50PX2D... • Answered on Oct 11, 2014
Zenith z50px2d stuck in zoom how do i adjust
Read the manual about changing the Aspect Ratio. There'll be a button for it on the remote and also an option to change it via the TV's onscreen menus.
9/7/2014 6:08:45 PM • Zenith Z50PX2D... • Answered on Sep 07, 2014
Zenith Plasma HDTV
Sounds like sustain board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
7/16/2014 7:54:05 PM • Zenith Z50PX2D... • Answered on Jul 16, 2014
0answers
Zenith Z50PX2D 50 in. Plasma HDTV Logo
349 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
dont picture but sound might issue
  • Televison & Video
