20 Most Recent Frigidaire ATF6000ES Front Load Washer Questions & Answers
Hello, Thank You for using FixYa. I will be helping you today.
push the Spin Speed and Soil Selection keys simultaneously and hold
until you hear a beep. This is no more than 10 seconds
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Frigidaire... | Answered on Dec 04, 2019
Frigidaire washer sucks. I'm tired of this useless machine ripping my clothes. You need to change your bellows(boot) kits around the door on front load. I have changed this kit twice now and each time, I spent $200 in repair fees. I wished I never bought this washer. Will never recommend to anyone i know.
Frigidaire... | Answered on Apr 12, 2019
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Frigidaire... | Answered on Nov 06, 2018
"pause" isn't something you can reset exactly I'm afraid. Pause means that the washer door was opened mid cycle so all you should need to do is shut the door to restart the cycle. Unfortunately if it doesn't re-start, it means that your door latch assembly has failed and isn't sensing that the door is shut. You'll need to order and replace the door latch assembly to fix the issue.
It's actually a fairly easy part to replace if you're handy. You'll need to unplug the washer and open the door to start with. Then there is a wire ring around the front lip of the rubber door gasket. Use a flat head screwdriver/needle nose pliers and pry the wire ring off. From there you can pull the gasket back out of the way. Remove the screws going into the door latch from the front and reach behind to replace the door latch assembly.
Make SURE the door strike on the door isn't broken too.
that's only a 6$ or so item.
Here's a site for parts and a video on how to replace it.
https://www.repairclinic.com/PartDetail/Door-Switch/131763256/4547033?modelNumber=ATF6000FS1
Hope this helps you.
Frigidaire... | Answered on Feb 17, 2018
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Frigidaire... | Answered on Feb 03, 2018
you need to call a repair service . the control board has failed
Frigidaire... | Answered on Jan 30, 2018
Probably the cycle timer has failed.
Frigidaire... | Answered on Jan 05, 2018
there seems to be a problem in the water pump as its not draining properly check that there's not a button or other debris in the system first eric
Frigidaire... | Answered on Dec 29, 2017
-Have you try to "Drain and spin " cycle to finished its cycle's program ? If not then try it.
Good luck
Mai
Frigidaire... | Answered on Nov 27, 2017
It sounds like the pump has stopped and may have sucked a sock or rag into it. May need to pull the washer out, remove the back. Unplug the washer and see if you can manually turn the pump/motor belt. It could also be the motor but I would check to see if they turn. If not, remove the belt and manually try to turn each and see if they turn.
Frigidaire... | Answered on Nov 20, 2017
Sounds like you got a broken drum spider usually due to overloading. And that's a major break down quite expensive but can be done.
Frigidaire... | Answered on Nov 19, 2017
Did you try pouring some white vinegar into it a few times? This may work. God-Bless! you might have to do this a few times, And let it sit for a bit.
Frigidaire... | Answered on Oct 06, 2017
Frigidaire ATF6000ES Front Load Washer Logo
3,279 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
go clean cycle frigidaire affinity
  • Washing Machines
