20 Most Recent
Jenn-Air JCD2295KES Stainless Steel Questions & Answers
How to add freon
Tara,
Most places require a certified technician to be able to add Freon to a refrigerator. You have to have special tools and the proper knowledge to know how to do that. I would suggest calling a service tech. You may have a different problem and may not need Freon. Hope this helps!
4/22/2015 4:43:44 PM •
Jenn-Air...
Answered
on Apr 22, 2015
Service manual
Having a water dispenser continually flowing is possible but it is very possible the
67006531 Dual Water Control Valve that is located on the back and near floor of most refrigerators is stuck open mechanically. There also could be a broken micro switch behind the pressure paddle where you press you glass against to get water. Here is a
JCD2295KES Service Manual I believe you asked for. I am here should you have questions, Thanks
Sea Breeze
4/28/2013 4:52:48 PM •
Jenn-Air...
Answered
on Apr 28, 2013
I have Jenn-Air JCD2295KES, freezer
A freezer is great for storing additional food that may not fit in your fridge freezer. If your freezer stops working, it's important to be able to troubleshoot it quickly so that food waste is kept to a minimum. Keep the following tips in mind if your chest freezer stops working.
Check the Electricity
If your chest freezer doesn't seem to be working at all, check the outlet that the freezer is plugged into. Unplug the chest freezer from the wall and plug something else in such as a lamp or digital clock. If the new appliance doesn't work either, you know the problem is with your outlet and not your freezer. If the appliance does work, you will need to refer to other troubleshooting methods.
Inspect the Relay
The relay is a component that helps power the compressor. It is housed in a plastic box with the motor terminals and the overload protector and is connected to the Compressor; the relay is the largest component in the box. Closely inspect the relay and make sure it is not burned out. The relay can also be tested using a multimeter. If you see any signs that the relay has shorted out, you'll will need to replace it. If the relay makes a rattling sound when shaken, this is also a sign that it has shorted out.
Examine the Compressor
The compressor is essential to the performance of your chest freezer. It is the motor that powers the entire cooling system and if your freezer has ceased to work, you need to check it. This unit is located at the back of the freezer and sits in plastic housing; it can be identified by its football shape.
You can tell that the compressor is broken if your relay is fine or if you hear a light hum followed by a clicking sound and silence. If your freezer is relatively new, it might still be under warranty and you could get a replacement compressor for free. If not, your compressor will need to be replaced by a professional.
Investigate the Thermostat
The fact that your freezer is not working could be down to the thermostat. This is the unit that regulates the temperature inside the freezer. To test your thermostat, remove the access panel on the side of the freezer. Next, use a screwdriver to remove the actual thermostat from the inside wall but do not disconnect the tube that runs from the unit into the freezer.
Set the range scale on Rx1 on your multimeter to test for continuity. If your multi-tester reads continuity, your freezer problem lies in another spot. If your multi-tester does not read continuity, it means your thermostat is not working and you will need to replace it. Remove the tube from the old thermostat and attach it to the new one. Screw the new unit into place on the freezer wall and make sure the tube is not coiled or kinked as this will prevent the new thermostat from working properly.
Good luck.....
8/8/2010 10:44:53 AM •
Jenn-Air...
Answered
on Aug 08, 2010
I have this fridge: jcd2295kes
For starters, use a couple of styrofoam coolers to protect your food. Then you can wait for the tech to return. The symptoms you now have are related to his work so he will want to fix it.
3/2/2010 12:00:58 AM •
Jenn-Air...
Answered
on Mar 02, 2010
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
5/20/2009 4:37:26 PM •
Jenn-Air...
Answered
on May 20, 2009
Original cost of my fridge from 1999
2389 model
Jeff of Clayton, CA
Original review: June 2, 2006
We purchased a
Jenn-Air JCD2389GES side by side four years ago. We thought we were buying a quality refrigerator, with a name brand that was respectable and with the idea that you get what you pay for. We went ahead and spent
$2200 on purchasing this and within a year noticed that it made noises, the refrigerator side didn't stay cold and the freezer side froze food that developed freezer burn with in a week. Just this past week the refrigerator was on the coldest setting and the food was slightly above room temperature. A hundred dollars of food had to be thrown away.
The best way to find old prices is to find reviews. The best ones are on websites that do reviews themselves as they always list the price.
https://www.google.com/search?q=jenn-air+jcd2289atb+review
5/30/2022 4:00:51 PM •
Jenn-Air...
Answered
on May 30, 2022
