20 Most Recent All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Questions & Answers
Might have a bad board or relay .
Check to see what turn the fan on because your fan should run when heater reaches a certain temperature.
All-Pro Kerosene... | Answered on Apr 20, 2018
Similar heaters that use diesel have to routinely cope with the dye added to untaxed fuel, ditto similar heaters that use both fuels. Unless there was an excess of dye in the fuel you used the problem was probably a coincidence.
Dirt can be a big problem due to corrosion forming in the fuel tank caused by a relatively large percentage of moisture naturally in the fuel and the formation of condensation. Fuel is generally filtered through a fine gauze when the tank is filled but there is little or no filtration preventing dirt already in the tank from being picked up and finding a way into the spray head which generally jams the spinner affecting the quality of the fuel spray.
Cleaning the spinner and nozzle might work for a while but only a major clean out will restore reliability until the next time. It is also wise to check and adjust the pressure of the air pump.
All-Pro Kerosene... | Answered on Feb 18, 2018
You can check the capicator. This is mounted next to fan motor.
There should be 2 wires going to it
All-Pro Kerosene... | Answered on May 19, 2017
Could the fuel be too old? I would recommend dumping the fuel in an outdoor firepit and burn it up. Use an inexpensive "Turkey Baster" to suck it out of the tank. Then put fresh kerosene in and try it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
All-Pro Kerosene... | Answered on Apr 02, 2017
Usually it is one of the hoses that goes to the burning unit. One hose supplies fuel the other I think is a air pump hose. If either one has a crack in it or is not connected tight, it will not provide the proper pressure for the igniter to work. Check both of the hoses and I bet you will find one of them that is bad. Replace them and it will work again. Mine has done this every year.
All-Pro Kerosene... | Answered on Feb 07, 2016
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
All-Pro Kerosene... | Answered on Jan 30, 2016
heatman101
All-Pro Kerosene... | Answered on Oct 10, 2015
A cad cell is a photo-electric device that reads the UV rays given off by flame after it has ignited. If it does not 'see' the flame, due to a flame failure OR a cad cell failure, the control circuit is locked out.
Make sure there is no carbon on the front (window)of the cell and make sure its adjustment is in perfect alignment to the flame.
All-Pro Kerosene... | Answered on Feb 19, 2015
This is normally due to either a clogged intake filter, or water in the fuel. To rinse the intake filter and the tank, put in a quart of fuel and shake, shake, shake to rinse crud off filter and dump out. Otherwise you'll have to disassemble to get to the filter. To remove water from fuel, dump it into a bucket. The water will coalesce in the bottom, then pour slowly back into the tank, leaving the 'bubble' of water in the bucket.
All-Pro Kerosene... | Answered on Feb 18, 2015
As you should know thermostat is for safety and it is not good idea to by pass it ,not recommended
All-Pro Kerosene... | Answered on Feb 05, 2015
Kerosene is best. It's better for the machine as it's cleaner and will need less maintenance plus it won't run smokey
All-Pro Kerosene... | Answered on Feb 03, 2015
below is a picture of the motor, if you look at the wires you will see a round canister like object with 2 wires going to it, that would be the capacitor.
All-Pro Kerosene... | Answered on Jan 21, 2015
I have a 100,000 allpro Kerosene heater I get sprake but won't lite I need help Thanks
All-Pro Kerosene... | Answered on Jan 20, 2015
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
376 questions posted
Top All-Pro Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • All-Pro Heating & Cooling
Most Popular Question
remington 100 heater running fine
  • Heating & Cooling
