20 Most Recent
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Questions & Answers
Can i hook two 500 gallon propane tanks together
yes you can but please get a propane gas certified engineer to do it , its really a job to be done by experts , the explosive power of propane is just to dangerous to mess with
How to connect two 1000 gal lp tanks together
Assuming that you want only one tank to run out at a time, you will need to set each at a different supply pressure, then Tee them together on the delivery side of the regulators. You will need pressure-holding regulators. Pressure-relieving type will not work unless you add a one-way backflow prevention valve after the regulator in the branch that is set to lower pressure.
Bottle freeze
the pull on the bottle makes it freeze the lpg has to bubble to make gas if the line off the bottel is too small and the heater draw is large the the bottle will freeze, so bigger tank and bigger draw off line .
I have a spc-40 heater i can not get it to stay
Ensure all your connections are tight and not leaking. I would shot off the tank using the valve on the top. Disconnect it, then re-connect it. Once connected, ensure the fan on the unit starts to turn. Then you can slowly open the valve, give it a good 4-5 turns to ensure it is open. They try the ignition sequence again.
