20 Most Recent Whirlpool GBS307PR Electric Single Oven Questions & Answers
2answers
E1 F5 Error Code RPD-305-PDS14 Whirlpool Double
An E1F5 coupled with an E1F2 or E0F2 all indicate a faulty touchpad. Fixyourboard.com offers replacement Ledgestone Technologies touchpads for Whirlpool and Kitchenaide oven models. Reach out to them for more information 512-355-1108 or [email protected] fullsizerender-crjxtk2pui4xc5qqbhljddcq-4-5.png kp1b1705a3-crjxtk2pui4xc5qqbhljddcq-4-9.jpg
6/19/2019 3:15:53 PM • Whirlpool... • Answered on Jun 19, 2019
Oven light won't turn on or off with the switch
it is an electrical problem and if you do not get in a qualified technician to fix the problem it is a jail term for any one not qualified who works on, or authorizes any work by unqualified persons should any person get a shock or be killed
6/19/2017 3:45:40 AM • Whirlpool... • Answered on Jun 19, 2017
2answers
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
5/5/2017 2:38:57 PM • Whirlpool... • Answered on May 05, 2017
2answers
Error code e1 f2
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
http://www.appliancepartspros.com
F2 - E1
Keypad cable unplugged
8/19/2015 2:57:35 AM • Whirlpool... • Answered on Aug 19, 2015
0answers
2answers
E1 f5 error code whirlpool gr399lxhs
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
6/20/2012 8:02:06 PM • Whirlpool... • Answered on Jun 20, 2012
Cant get my elecric single
You need to check the continuity of the wires from the mains plug to the main heating coil. This means that the switch and the circuit to the heating coils will confirm the short. If the heating element is short then the main line should be removed to confirm the short and so the circuit will not trip.
8/18/2011 11:40:03 AM • Whirlpool... • Answered on Aug 18, 2011
0answers
I have a whirlpool built
Hello, welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, that is the component that typically trips/activates during a self clean on many ranges.
Unfortunately you'll need to pull the oven from the cabinet. If you pull/slide the unit away from the wall and unplug it you can replace the hi-limit. It will be a non-reset type hi-limit (based on the model number you posted) so needs to be replaced as I mentioned, doing so will get you back up and cooking in no time.
**Unplug the range from the wall first of course...safety first**
Once you remove the panel you will need to look for a switch/thermostat which looks like this...
Let me know how you make out. Good luck.
I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
6/2/2011 2:40:35 AM • Whirlpool... • Answered on Jun 02, 2011
My oven is not baking
It's possible the lower bake element is not working. If the oven takes a long time to come up to temperature, that's a good indication that a baking element (bottom, broil element is on top) is bad.
4/27/2011 1:37:33 PM • Whirlpool... • Answered on Apr 27, 2011
I have an accubake electric
It sounds like the electronic timer/clock is in the automatic mode. It must be in the manual mode for the oven to work.
2/27/2011 2:22:58 AM • Whirlpool... • Answered on Feb 27, 2011
Brand new and wont heat up?
plug it in
1/29/2011 8:44:53 AM • Whirlpool... • Answered on Jan 29, 2011
Why does the cook light stay on?
it is a very hard worker.
1/29/2011 8:43:28 AM • Whirlpool... • Answered on Jan 29, 2011
Whirlpool GBS307PR Electric Single Oven Logo
53 questions posted
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
error code e1 f2
  • Ovens
