20 Most Recent
Whirlpool ACQ158XP Wall/Window Air Conditioner Questions & Answers
Aez05lqw1
remove from window, take outside and clean
9/6/2015 9:38:35 AM •
Whirlpool...
Answered
on Sep 06, 2015
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
3/6/2015 5:35:08 PM •
Whirlpool...
Answered
on Mar 06, 2015
Unit lights up and hums but does not blow air
mcdevito75 here, Sounds like the fan motor is haging up or needs to be replaced, try the switch on/off then on/off a few times see if the fan kicks on, if not see your local a/c repair shop, they come to the house.
7/6/2014 8:12:39 PM •
Whirlpool...
Answered
on Jul 06, 2014
Acq158xr1
That is typically a tale tale sign of ice. Thaw the unit by circulating the fan for a few hours. That's the easiest and cheapest repair.
12/7/2013 1:51:16 PM •
Whirlpool...
Answered
on Dec 07, 2013
My home AC is not working my compressor come on
1st check breaker box to see if you have power (tripped breaker)
If you have power you should have a licensed contractor diagnose it.
Caution the voltages in testing can be high, even deadly if you don't know what you are doing. You must have the proper tools to test.
3rd check 24v signal power.
4th test the capacitor to see if it is within 5% of rating
5th is there a start kit/compressor saver/5-2-1/start assist, or does it need one.
6th test windings and add up the resistance.
12/7/2013 1:42:34 PM •
Whirlpool...
Answered
on Dec 07, 2013
