20 Most Recent
Muratec MFX-1430 Copier Questions & Answers
How do you reset the
you should ONLY replace the Toner cartridge when the machine tells you to. NOT when it says replace "soon". If this has occurred..the fuse in the cartridge was blown prior to the time that the cartridge should have been installed. Now the machine is asking for a new cartridge but the fuse has already been blown. Contact a Muratec SERVICE rep if you are unable to replace the fuse yourself.
How select bypass tray
There are two ways to select the bypass.One way is from the pc...This involves selecting to print and then in preferences picking the bypass.The other method of selecting the bypass is from the copier.To select the bypass for copying press bypass, press others, press bypass, select paper type and press enter.
MFX 1430 SUPPLIES I’m happy to assist further over the phone at
https://www.6ya.com/expert/norman_d2fa496dce30c65d
How can I clean the
Hi when you say clean the drum the drum is cleaned by the drum cleaning blade if the blade is no good then the drum will not be cleaned if you want to clean the drum you canuse a very soft cloth lint free
to clean the drum
it is not really something you clean unless like you got a label stuck on the drum once they reach there life they need to be replaced as you can create a lot more issues with the machine
Can't dend a fax via
Have you ever been able to do this,...was it ever set-up properly to have this feature working.???
Check the installation instructions are set up properly and things like your e-mail address and POP accounts are set properly.
Our Muratec MFX1430, ADF will not feed mulitple
Yes...contact a copier dealer who also sells Muratec...most likely that the broken Left hinge on the ADF is the cause of your feeding problems....probably about $25.00...the part in the paper tray Don't know..never had anyone break one.
If you cant find a dealer have a look on Muratecs web site for a contact #...their web site is
www.muratec.com
I PUT A NEW TONER AND IT IS SAYING THERE IS EMPTY
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the case...you can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Can you adjust the edge
Unless someone has changed it(made it larger)...factory default is 2mm void at the edges and you can't make it any smaller than that.
Papers that are faxed over
Pages recieved go into memory if there is a problem...for example, no paper, no toner, some kind of "error" code or alarm on the machine....if you are unsure..switch the machine into the copy mode and make a copy and see if the page prints out ok., if it does then there is no reason for the pages not to print out when received. See if the display is saying anything odd.
The start and stop buttons stopped working. I
It is very odd that 2 buttons would stop working just because you changed the toner... if Muratec tech support had you do a system reboot and it did not work then I would be concerned that you have a PCB problem....as long as there are no other alarms or indicators that you are not mentioning.....IS THE MACHINE ON A SURGE PROTECTOR.?????
