20 Most Recent
Muratec - MFX-1300 Copier Questions & Answers
Please call service
The most likely cause is either the fusing unit located in the right side door (orange in color) or a main motor lock. To determine what the trouble is, you need to enter the maintenance mode. On the control panel, press the "program * 6 keys in order. Press the right arrow key until service mode is displayed and press enter. If the display says heater error you have a bad fusing unit. If it says Rx motor, then the main motor is locking up. Check the drum and toner cartridge for motor lock problems.
8/4/2012 2:38:23 AM •
Muratec -...
Answered
on Aug 04, 2012
Please call for service
If the machine is saying "Please Call Service"..you will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Mssge will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common( given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
11/4/2011 7:32:10 AM •
Muratec -...
Answered
on Nov 04, 2011
Muartec 1300
error message .....Please call
Hi this is a standard message when the machine needs to be seriviced or parts need to be replaced because they have reached there life it is best to have a certified engineer service the machine for you
2/15/2011 5:31:40 AM •
Muratec -...
Answered
on Feb 15, 2011
We have been given an
Hi yes it may be caued by the charge roller arching or damaged replace the charge roller
also check the transfer seperation unit for arching
the above will fix this issue
2/14/2011 1:37:55 AM •
Muratec -...
Answered
on Feb 14, 2011
My copier say open side cover and remove paper
Because it "thinks " there is a piece of paper jammed.
Open the machine make sure there is no jam, take out the paper cassette and check or change the paper for fresh paper...put the cassette back in and try to make a copy again. As a last resort try making a copy with a piece of paper thro the "by-pass" tray and see what happens.
11/16/2010 3:42:27 PM •
Muratec -...
Answered
on Nov 16, 2010
CHANGED TONER NOW A BLACK SMUDGE DOWN SIDE OF
There is a Black plastic cover that you close down on top off the toner cartridge....open that up and on the underside of that plastic cover you will see a row of small glass eyes...give them a wipe with a cloth or your finger as you may have gotten toner or dirt on the eyes.
11/5/2010 12:31:40 PM •
Muratec -...
Answered
on Nov 05, 2010
HOW TO I CHANGE CONFIRMATION REPORT
Instructions are on page 3.21 of the operators manual.
To switch the Report ON/OFF do the following....
Press PROG, C,1, 0, 3, ENTER.
pRESS to toggle setting On or Off...Press ENTER to save the setting.
11/2/2010 8:28:23 PM •
Muratec -...
Answered
on Nov 02, 2010
I cannot connect my MFX 1300 printer to my home
Yes...the MFX-1300 was only a copier/fax machine when originally sold, so there was no facility to connect to a P.C.
To connect to a PC there was an Optional Printer Control PCB available.
11/2/2010 5:26:03 PM •
Muratec -...
Answered
on Nov 02, 2010
Just installed a new drum. and still get the
The new cartridge came with some paper work and you have to reset the life counter. I should be under the user funcation. Or you may have to have the cover open and turn it On. and follow the instructions
9/15/2010 3:04:34 AM •
Muratec -...
Answered
on Sep 15, 2010
We replaced new drum and
The drum should only be replaced when the display says "REPLACE DRUM" ...NOT when the display says "Replace Drum Soon"
...try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT
9/5/2010 2:16:44 AM •
Muratec -...
Answered
on Sep 05, 2010
How do you make two-sided copies?
Afraid this is a "Simplex" machine. To make duplex copies you will have to put paper back in cassette to copy onto second side, and then turn original over on glass or into doc feeder.
5/28/2010 3:32:31 AM •
Muratec -...
Answered
on May 28, 2010
