I have an AEG SANTO OKO fridge unit only about 1 year old.
We just cannot open the door without it being pulled 2 inches on every open. I have since placed it on a rubber mat with no success
You have very good door-seals,
with strong magnets on the refrigerator.
I suspect, You must pull hard to open the door.
Does the fridge have 2 wheels?
It may only stand firm on 2 "legs" and not 4.
This problem is the first, I ever heard,
I do not know this model,
If it is a Refrigerator that is not very heavy, this can happen.
When the door seals are very good, what can happen is
The door has been closed and the air inside the fridge becomes cooler and cooler.
The air inside the food-compartment contracts,
because it cools down and pulls even more on the inside of the door surface, actually pulling the door shut.
( a negative air-pressure inside the fridge) compared to
the outside of the refrigerator.
A trick I am using is,
1.)
I place my finger between the door and the cabinet-frame.
2.)
Then, with the finger, index or middle finger,
I push gently
against the Door-Seal (Gasket).
for 1 or 2 seconds,
This allows the Air from outside, (higher pressure)
to flow into the food compartment of the fridge
and now it is easy to open the door.
Let me know if this works for you.
Appreciate to be alive and be kind to others.
Klaus
(Electrical & Refrigeration Technician)
Toowoomba, AUS
2/6/2018 11:14:37 PM •
AEG...
Answered
on Feb 06, 2018
