20 Most Recent Amana ACD2232HR Side by Side Refrigerator Questions & Answers
We hooked up the water line for the ice maker.
Take back cover off near compressor and maybe front grille at bottom and shine a light to see if you can see what is leaking under unit.
10/30/2017 3:41:00 PM • Amana ACD2232HR... • Answered on Oct 30, 2017
ICEMAKER DONT MAKE ICE QUBES
Sometimes I do not get ice either. check the wire that hangs over the ice bucket. Sometimes this gets hung up and it thinks that it is full of ice.
1/13/2014 3:54:19 PM • Amana ACD2232HR... • Answered on Jan 13, 2014
Freezer was not working this
Test Defrost Timer # 9 in this download http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28327585&pkw_=basket&model_id=5167318&NewWindow=1
The defrost timer is usually found in the temperature control console.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode.The freezer fan motor should have stopped now in defrost mode. Simply wait about 35 minutes and check whether it has moved out of defrost mode and has resumed cooling (listen for the compressor and freezer fan motor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multimeter. Set the multimeter to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the white wire in the connector plug.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multimeter should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
9/18/2011 8:18:11 PM • Amana ACD2232HR... • Answered on Sep 18, 2011
Compressor runs replaced start and
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/3/2011 11:43:12 PM • Amana ACD2232HR... • Answered on Sep 03, 2011
Amana ASD2522WRW03 - tHIS UNIT
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
8/28/2011 5:49:20 PM • Amana ACD2232HR... • Answered on Aug 28, 2011
The fridge is not cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
8/8/2011 10:42:47 PM • Amana ACD2232HR... • Answered on Aug 08, 2011
Fan is working but both
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/5/2011 9:50:12 PM • Amana ACD2232HR... • Answered on Aug 05, 2011
What do the numbers or setting mean. Is 1 warmer
1 is warmest
7 is coldest
7/30/2011 12:55:39 AM • Amana ACD2232HR... • Answered on Jul 30, 2011
I have an amana side
Adjusting Ice Maker Fill
Use a flat-head screwdriver to remove the screws on the ice maker's front access panel, and then remove the panel.
  • Locate the adjustment screw, located about mid-point on the side of the ice maker. Do not turn the crew more than one full turn in either direction.
  • Turn the screw clockwise ½ turn to decrease the water fill level.
  • Turn the screw counterclockwise ½ turn to increase the water fill level.
  • Close the access panel and restore the screws. Turn the refrigerator back on.
  • bobicehouse_20.jpg Look at mid point for adjusting screw
    7/10/2011 5:35:01 PM • Amana ACD2232HR... • Answered on Jul 10, 2011
    Water leaking on a Amana
    water flow tank full. remove the tank.
    5/6/2011 2:49:07 AM • Amana ACD2232HR... • Answered on May 06, 2011
    I have an amana ars2664ab sounds like the
    As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
    Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
    Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
    http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
    Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
    http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
    http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
    heatman101
    6/21/2010 5:24:34 AM • Amana ACD2232HR... • Answered on Jun 21, 2010
    My Frigidaire side-by-side leaks inside, from water filter
    the gasket that holds the water pressure in between the water inlet line and filter is not in proper position, or your filter sir is nt properly inserted into the slot,the cycle starts when the water comes in,pressure will build up and it will start t pass in between the gap, as the pressure goes down, dripping will stop, then cycle start again, check the connector sirandhose connected into the filter
    3/19/2010 3:53:12 PM • Amana ACD2232HR... • Answered on Mar 19, 2010
    Changed water filter and now water is leaking from
    filter isnt in right
    2/25/2010 12:40:18 AM • Amana ACD2232HR... • Answered on Feb 25, 2010
    Kenmore model 106.57022601 side by side. Ice maker
    Check the button that the lever pushes when calling for ice. Also check voltage to the auger motor. If your ice bucket is in the door then your auger motor is under it...also in the door. There is a little cover under one of the freezer door shelves that you have to take off. 3 or 4 screws hold it on. Right in there you will see the auger motor
    9/11/2009 6:43:32 PM • Amana ACD2232HR... • Answered on Sep 11, 2009
    Amana ACD2232HR Side by Side Refrigerator Logo
    Popular Tags
    56 questions posted
    Top Amana Refrigerators Experts
    ZJ Limited
    ZJ Limited
    Jay Finke
    Jay Finke
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
    View Most Popular
    Amana Refrigerators
    • Amana Refrigerators
    Most Popular Question
    numbers or setting mean 1 warmer
    • Refrigerators
