20 Most Recent
Bissell 9200 Upright Vacuum Questions & Answers
Brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?page=3&q=bissell&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
My electrolux versatility vacuum doesn't have much suction
If you are experience less or no suction of you vacuum, most of the time there is a blockage that clogs up your unit resulting to this. Turn off your vacuum first and unplug the machine from the power before doing any troubleshooting with your vacuum. Remove the attachment hose and check inside the hose and the openings where the hose attaches for any blockages. You may refer to your manual below for troubleshooting solutions:
Electrolux EL8502 User Manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=electrolux
Ava B.
Won't spray
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Loud noise and smell of rubber over heating
sounds like you have something stuck in the beater bar/roller and the belt is slipping. You're probably going to have to take it out and replace the belt. Also check for wads in the passages.
How come my brushes won't turn
Hi, it's Cindy from Crucial Vacuum,
Your Bissell 9200 Proheat 2x vacuum's brushroll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. Another cause could be there is debris stuck on the roller and/or bearings. To gain access to your belts and check the source of the problem, please refer to page 15 of your manual, a direct photo is attached.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
