20 Most Recent
Fedders AED24E7F Wall/Window Air Conditioner Questions & Answers
Ac temperature won't go above 31
Halo
Clean the indoor unit filters and wash the outdoor unit condenser with a hose and see if that works.
Then after that has been done, set the AC unit on cooling at its minimum temp and then go to the outside unit and after a couple of minutes you'll see the thick pipe ice up.
When you see that wait 20 more seconds then tip you finger on your tongue and press it against the pipe +-5 cm away from the valve its suppose to stick.
If not you will need to get professionals to service it or contact me and I can guide you step by step.
Regards
Remote control
First you have confirm what really the defects is, is it the remote control or the control board.
HOW TO CHECK THE DEFECTIVE REMOTE CONTROL:
Check if the remote control if still good, using the camera of your
cellphone point remote control to the cellphone camera and press the
"on" button of your remote and you can see the light emitting from your
remote control transmitter. If the lights emits that means your remote
control is good, if not means the remote control is defective. If the remote emits light it means that the receiver at the control board
in the indoor unit is defective.
