20 Most Recent Maytag Freezer MQU2057 Questions & Answers
Freezer MQU2057: Maytag freezer on bottom froze up (literally frost...
Your tech doesn't have the issue completely fixed. You have a defrost issue and defrosting manually is just the start to resolving your issue. You have to diagnose why it fails to defrost. You have a heater, control thermostat,frost sensor, etc. to check for a failure after defrosting it. Get someone that knows how to complete the job right! I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 10:28:57 AM • Maytag Freezer... • Answered on Dec 31, 2017
Ice forms on the lower
The drain from the freezer is at the base of the evaporator section.
This is behind a plastic cover at the back inside, which must be removed to see it.
There should be screws visible, or clips which must be removed first. Often these are covered with plastic covers too.
Use a mould-killer spray, and a length of PVC covered wire to clear it.
12/25/2010 5:50:11 PM • Maytag Freezer... • Answered on Dec 25, 2010
Drain freezes and bottom ices up ii have thawed
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
9/22/2010 6:06:56 AM • Maytag Freezer... • Answered on Sep 22, 2010
We left the freezer door open accidently for 10
Hi, Check the rear panel inside the freezer and see if it has frost building up on it. If so, shut the refrigerator off for 24 hours or remove the rear panel and defrost it with a hair dryer.
It should be ok after that ubless the evaporator fan motor has gone bad.
Please let me know if this helps or if I can assist you further.
Vic
7/17/2009 1:40:51 AM • Maytag Freezer... • Answered on Jul 17, 2009
Technition called it freon noise
Sounds really strange to me. Not sure what kind of patch he could have used. I've never heard of "freon noise". Clicking and popping could be the thermal overload tripping and resetting. The unit should still be under warranty. I would contact them to get another tech and another opinion. It would be best to get this resolved before the warranty wears out.
1/31/2009 4:55:42 AM • Maytag Freezer... • Answered on Jan 31, 2009
Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
1/7/2009 4:58:24 PM • Maytag Freezer... • Answered on Jan 07, 2009
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
8/17/2008 5:18:17 PM • Maytag Freezer... • Answered on Aug 17, 2008
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
10/13/2007 6:18:58 AM • Maytag Freezer... • Answered on Oct 13, 2007
FREEZER NOT WORKING
that is very possible if the fan and compressor are running. the best thing you can do is call maytag. its only 4 months old and is there problem to fix. Good Luck
8/5/2007 3:21:34 AM • Maytag Freezer... • Answered on Aug 05, 2007
Where is the defrost timer located on a Maytag upright freezer model RFU200FAAW?
Most parts are obsolete, and the timer is expensive! https://www.repairclinic.com/ProductDetail/96494?page=3 Timer-Def Part Number:WP3-81329 In Stock, 1 available Note: (Series: B2) $82.10 Add to Cart 16 Defrost Heater Part Number:W11175809 In Stock Note: (Series: B2) The defrost heater keeps the cooling coils from frosting over. $71.30
10/2/2021 9:10:41 PM • Maytag Freezers • Answered on Oct 02, 2021
2answers
My maytag frezzer icebox is groaning
its the fan
1/15/2019 12:17:44 AM • Maytag Freezers • Answered on Jan 15, 2019
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
8/11/2017 2:10:41 AM • Maytag Freezers • Answered on Aug 11, 2017
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk. Your problem should be air leakage into the machine. Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer. The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak. Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will. P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-( God bless your efforts.
7/7/2017 6:22:49 PM • Maytag Freezers • Answered on Jul 07, 2017
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
5/2/2017 7:04:48 PM • Maytag Freezers • Answered on May 02, 2017
Maytag Freezer MQU2057 Logo
12 questions posted
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Freezers
  • Maytag Freezers
Most Popular Question
drain freezes bottom ices up ii thawed
  • Freezers
