20 Most Recent
Maytag MAV3905EWW 13 Cycle Washer Questions & Answers
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
3/19/2010 12:18:52 AM •
Maytag...
Answered
on Mar 19, 2010
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
3/14/2010 5:37:20 PM •
Maytag...
Answered
on Mar 14, 2010
Wobbles when spinning
The load of clothing/towels is out of balance.. you can readjust by hand. Also check the washer feet. they are on screws and you can adjust them with a wrench to relevel the machine and for all four legs to be in contact with the floor... that should help alot...
KEN
5/10/2009 2:04:22 AM •
Maytag...
Answered
on May 10, 2009
Easily off balanced
bad snubber ring, after a while especially if you have heavy loads your snubber can get worn out and the machine will go off balance VERY EASILY. the snubber lies beneath the whole transmission assy, it is usually white in color a moderately big repair job, there are shortcuts but too lengthy to go into here.
4/7/2009 9:48:34 PM •
Maytag...
Answered
on Apr 07, 2009
Washer will not spin on the regular cycle but does on the delicate cycle??
Dear friend,
ngfam at you service!
You have an electronic problem and have no choice but to call service!
If the washer is 10 years or older its not worth investing money to
fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide -USA
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
8/28/2008 2:00:09 PM •
Maytag...
Answered
on Aug 28, 2008
Fix for error code E02F06 on Maytag mhw7000xw front load washer
I found this reference on the web ... from a repair technician on a Maytag Maxima>>>
So I'm really sorry to bring you this bad news, but let me explain your error codes. F06 E02 is a communication error between your MCU (motor control unit) and your CCU (central control unit). You'll want to remove the top panel, the control panel, and then the front panel of the washer and make sure the wire connections to the motor control unit below the tub are all secure. If everything checks good, you'd need to have the MCU replaced.
From a different reference on a similar Maytag MHW6000XW2 ... also indicating communication issue
Usually ... hidden somewhere on the inside of the washer you will find the service technician paperwork which has all sorts of additional detail.
Helpful?
Good luck on your troubleshooting!
Maytag top loading washer with UL code
Leveling: Ensure the washer is properly leveled. An unbalanced load can trigger the UL (unbalanced load) code. Use a level to check if the machine is sitting evenly on the floor.
Load Distribution: Make sure the clothes are evenly distributed in the drum. An imbalanced load can cause the UL code to appear.
Calibration: Some models have a calibration mode that can be accessed through the control panel. Running a calibration cycle might help the washer to detect load balance more accurately.
Electronics: There could be an issue with the control board or wiring harness. Inspect these components for any visible damage or loose connections.
Professional Service: If none of the above steps resolve the issue, it may be time to consult with a professional appliance repair technician who can diagnose and fix the problem more accurately. They may have specialized tools and knowledge to pinpoint the exact cause of the UL code.
