20 Most Recent
Maytag Neptune MAH6700A Front Load Washer Questions & Answers
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
