20 Most Recent
Maytag Neptune MDE6700A Electric Dryer Questions & Answers
He error. Heating element 11ohms, fuses and thermistor all test OK for current - closed.
Listen, if you have 240 at the wall then the full 240 or 120 a piece is not getting to your element. Something, a contact or switch is open on one of the two lines and unless both are properly feeding the heating element there is no way it will ever heat up!
Using an ohmmeter, trace the wiring back for the wall connection to each of the two legs connected to the element. One of the legs is open!
Dryer wont heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
