20 Most Recent Magic Chef MCBR440 Compact Refrigerator Questions & Answers
I have Model No. MCBR360S Mini Refrigerator- It
That clicking sound is the compressor trying to start, if it is less than a year old just call magic chef and they will replace the unit, if not the cost of a sealed system repair may make it not worth reairing
9/1/2018 3:23:47 AM • Magic Chef... • Answered on Sep 01, 2018
My mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
7/9/2018 4:01:10 PM • Magic Chef... • Answered on Jul 09, 2018
2answers
I have a MC compact refrigeratior BR445W1 that was
Have you tried unplugging it for 5 min's to see if it resets?
3/3/2018 1:38:37 AM • Magic Chef... • Answered on Mar 03, 2018
Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
9/13/2017 4:57:52 PM • Magic Chef... • Answered on Sep 13, 2017
3answers
My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
5/2/2016 2:58:58 AM • Magic Chef... • Answered on May 02, 2016
What current would be drawn by a 15kw 400v ac motor with a locked rotor
15.000 Watts divided by 400 Volts = 37,5 Ampere. You can't predict the start current. That peak is much higher.
7/14/2014 2:22:37 PM • Magic Chef... • Answered on Jul 14, 2014
WHATS THE PRICE OF COMPRESSOR RELAY FOR VISSANI HVWC28ST
I would recommed contacting the Magic Chef web site to order the right part. I did and it was well worth it and my replacement seal worked perfectly.
6/26/2014 4:57:58 PM • Magic Chef... • Answered on Jun 26, 2014
0answers
0answers
Not cold enough
Be the first to answer 5/23/2014 3:27:11 AM • Magic Chef... • Posted on May 23, 2014Be the first to answer
0answers
Magic Chef MCBR440 Compact Refrigerator Logo
179 questions posted
Top Magic Chef Refrigerators Experts
Kardoc
vince
Paul Carew
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Refrigerators
Most Popular Question
model mcbr360s runs but any setting
  • Refrigerators
