20 Most Recent Estate TGDS840JQ Gas Dryer Questions & Answers
Drums turns but no heat
check, to see if the gas line is open to the dryer, if there's a shut off valve, make sure it's in the "open" condition. Check your electronic igniter----that's sounds like the most likely problem.
9/24/2012 4:31:23 PM • Estate TGDS840JQ... • Answered on Sep 24, 2012
Not getting heat
Gas dryer woes If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
7/28/2012 3:17:46 AM • Estate TGDS840JQ... • Answered on Jul 28, 2012
Dryer wont come on
Did the circuit breaker trip? If not You may have a bad internal fuse, motor, door switch, timer or start switch.
5/16/2012 5:24:59 AM • Estate TGDS840JQ... • Answered on May 16, 2012
2answers
Heating but drum does not turn
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
9/26/2011 5:57:32 PM • Estate TGDS840JQ... • Answered on Sep 26, 2011
Estate dryer TGDS840JQ1 does not heat. I've
Hello Bob,
The cycle thermostat sounds good to me the two wires on the top/bottom should be zero ohms 1.1 is fine the two across from each other are going to be in the range of 6-8k so they as well are fine. What ya need to check is the heat element itself it should be between 10-20 ohms
Whta you to check also is the 2 thermostats where the tube the burner asm. fits to in the rear of the dryer both of the should be zero ohms resistiance (1-5 would be ok) if you find either of them to be open that will be the reason the dryer isnt not heating
But on the gas dryer the most common thing that will make it not heat is going to be the igniter..need to check it not for ohms but when the dryer is running that their is 120 volts to it,if it has 120vac and doesnt come on the igniter is bad
if the igniter does not have 120 volts need to check the flame sensor(black rectangle peice on the side of the burner tube) for zero ohms before checking it be sure the power is disconnected since it if you touch it live it will shock you
if all above checks good either the timer or the motor will cause the dryer to neot heat as well
but i suspect it will either be the igniter of one of the thermostats on the housing in the rear where the burner tube fits into
Good luck,
GENE
9/20/2011 12:39:00 AM • Estate TGDS840JQ... • Answered on Sep 20, 2011
The dryer does not heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./';
8/13/2011 12:44:59 AM • Estate TGDS840JQ... • Answered on Aug 13, 2011
Won't heat up
heatman101][
8/13/2011 12:40:38 AM • Estate TGDS840JQ... • Answered on Aug 13, 2011
Dryer is not heating
heatman101
5/10/2011 10:48:50 PM • Estate TGDS840JQ... • Answered on May 10, 2011
It will not heat up
heatman101';'
5/1/2011 12:06:01 AM • Estate TGDS840JQ... • Answered on May 01, 2011
I have a whirlpool estate jgds840jq1 gas dryer, It
http://www.applianceaid.com/gas_dryer.html#noheat
4/30/2011 1:58:50 AM • Estate TGDS840JQ... • Answered on Apr 30, 2011
Hi, My
sounds like your gas valve is leaking through one or more of the gaskets. It definitely would be worth your while to fix the dryer considering the amount of propane you're losing. That's a big gas bill! Unless you have already tried it this way I,you could use a spray bottle with some real soapy solution you will probably find it.
4/12/2011 12:34:25 PM • Estate TGDS840JQ... • Answered on Apr 12, 2011
My dryer does not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
2/12/2011 10:06:55 PM • Estate TGDS840JQ... • Answered on Feb 12, 2011
Estate TGDS840JQ1 Gas Dryer NOT HEATING
heatman101
1/15/2011 3:42:06 AM • Estate TGDS840JQ... • Answered on Jan 15, 2011
I would like to know how to change the Drum Belt
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
1/11/2011 3:05:52 PM • Estate TGDS840JQ... • Answered on Jan 11, 2011
I have an Estate TGDS840JQ1 gas dryer and it does
First check to see that the gas burner is "trying to come on but doesnt". Pull the little plastic cover off and look through the little hole in the front as it starts. If you see the ignitor repeatedly glow then go off without lighting the gas, the problems with the burner (or you have no gas). If not, you can easily take the back off and check the fuses shown heresagacious.jpg
1/4/2011 5:10:08 AM • Estate TGDS840JQ... • Answered on Jan 04, 2011
I have no heat with
sdfs77Hello and sorry to hear about your problem.
It sounds like your dryer glow rod, is defective. This is the electronic pilot lite for the unit.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
12/22/2010 3:28:45 PM • Estate TGDS840JQ... • Answered on Dec 22, 2010
Ignigter will not light
heatman101
11/23/2010 4:56:43 AM • Estate TGDS840JQ... • Answered on Nov 23, 2010
Dryer turns on, drum rotates, clicks like it did
heatman101
11/23/2010 4:23:04 AM • Estate TGDS840JQ... • Answered on Nov 23, 2010
It has no heat when we turn it on we took it apart
you may need to light the pilot light at the valve going in to the dryer.If you have the owners manual it should tell you how to light it. Be careful it is not a hard thing to do but take caution and follow the steps correctly. If this has helped you don't forget to hit yes in the box and good luck friend!
10/10/2010 12:26:21 AM • Estate TGDS840JQ... • Answered on Oct 10, 2010
Estate TGDS840JQ Gas Dryer Logo
59 questions posted
Top Estate Dryers Experts
Paul Carew
Jorgie  the...
Jorgie the...
Are you an Estate Dryer Expert? Answer questions, earn points and help others
View Most Popular
Estate Dryers
  • Estate Dryers
Most Popular Question
estate dryer tgds840jq1 not heat
  • Dryers
