20 Most Recent
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Questions & Answers
Fisher & Paykel dishwasher drawer won't run, beeps F2 error code
Craig, we had virtually the same situation. The repair man came and it took 2 minutes to fix. The problem was that the bottom drawer had not been used for a couple of years and thus the impellor had jammed. to fix it take out the basket, lift off the rotor arm and unscrew the knob. Then just work the impellor around with your fingers until it frees. It then worked perfectly. We will use the bottom often from now on to prevent this happening again.
By now the left over pumpkin pie will be a bit green!!
11/29/2023 11:37:46 AM •
Fisher and...
Answered
on Nov 29, 2023
Both drawers Fisher Paykel DD603i start Beeping/Draining
the unit as had a lieak your it thinks it as first un plug the unit then try taking out the bottom draw (pull it all the way out then at the bottom front on both sides there is to clips push both clips in and pull the draw it wiil leaft of it runners push the runs back in out of the way then the can see under the in the base of the unit if the can see water or damp dathch plz call an enginner as ther is 5 things it can be
if not water you will see a grey plactic cover in the bottom back right the main pcb is in there witch has a water sencer on it if you fell up to 4remover the pcb and wiep the two prongs that are on the end of it as wiep there it was siting then put back as it was ps the dont need to take any wires to repalces the draw pull the to runners back out sit the draw on them then clothes the draw but re open it and give the to cilps a lite pull to make sure they are locked back in to places pulg it back in and try it if this dont work plz call an enginner as there is 3 pcbs in this unti that will need cheking
Fisher paykel dd603 stops while in cycle and beeps
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Can i disable the bottom drawer on a Fisher and Paykel dishwasher and only use the top drawer
You cannot disable, as in turn off, permanently, but you can turn off with the power (left most) button and then lock the control (right most button) by pressing and holding it for approx. 3-5 seconds. The lock symbol will illuminate. Now the lower drawer cannot be operated - unless the lock is released. You cannot disconnect the lower drawer as this will cause a U4 or similar error and both drawers will shut off.
F2 code. Followed listed
There are no wires underneath the rotor - it is just suspended in the cavity. So you cannot do any damage except make scratches around that area. Maybe take a straightened wire coat hanger and insert from the side hole in the filter sump area. You might be able to push the rotor up to an extent and then grab it with pliers.
F 5 error top draw only
Fault code F5 is a lid fault error. It could be one of many issues and generally will need a technician to fix it. The problem could as simple as the lid seal that seals the drawer being displaced or the actuator motors that bring the seal down being faulty. Turn the mains power off to the dishwasher and back on. This should bring the actuator motors to start position. If this does not fix it then check under the top housing for any signs of lid seal break. If it looks ok then you have to call technician to fix it. The fix involves taking the drawer out carefully without damaging the wiring and hoses underneath and checking the lid seal assembly underside of dishwasher housing.
F & P Dishdrawer DD6031
The Problem is Related to the Dishdrawers Motherboard Control Center This usually happens when water condensation sits on the board to long and Short Circuits controls.
How to replace outlet hoses on D D 603
In order to reach MOST of its components front facia have to come off. (so you can remove its bottom cover under the drawer).
This machine is VERY sensitive to leaks, so be very careful!
11/22/2014 12:01:44 AM •
Fisher and...
Answered
on Nov 22, 2014
Why does a fisher and paykel DD-603 randomly gives f1 code even when not in use
Fault code F1 can come from a number of different sources and can remain on as long as the machine has power (does not need to be operating). Once a fault is repaired it can be cleared by pressing the Power button. If the fault is still present then it will not
clear. The service manual says: The faults are displayed in the LCD as one of 5 F (fatal) faults or 1 U (user) fault along with the symbol of a spanner. A fatal fault will usually require the assistance of a qualified service person...
Fault Code Description:
Fault Code: F1
LED Display: Rinse LED
Fault: The flood switch has been activated for more than six seconds
Possible Causes
_ Inlet hose to inlet valve connection loose
_ Inlet valve body leak
_ Damage to the fill or drain hoses
_ Heater plate damage (chipped enamel)
_ Seals/O Rings (pinched, contaminated or poor join)
_ Dispenser (seal, diverter valve or weld leak)
_ Lid area (lid motors not functioning correctly, lid off yoke or foreign object interfering with lid seal)
Fault Code Problem Solving:
1.Question: Is there a F1 on both displays? Yes: Go to Question 2. No: If power fails to the bottom tub it will cause thetop tub to go F1. Test heater plate.
2.Question: Has a flood occurred? (N.B. The flood may have dried up) Yes: Go to Question 3. No: Go to Question 13
3.Is the lid sealing on the tub correctly? Yes: Go to Question 5. No: Go to Question 4
4.Question: Are the lid actuators functioning correctly? Yes: Go to Question 5. No: Check the lid actuators are assembled correctly on the slides and yokes. Check the plugs on the RFI board and the terminals on the lid motors. If the lid actuators look slow replace them.
5.Question: Is the water level in the tub high? Yes: Go to Question 6. No: Go to Question 8
6.Question: Is the water inlet valve leaking? Yes: Replace inlet valve. No: Go to Question 7
7.Question: Is the DishDrawer priming correctly? Yes: Go to Question 12. Go to Question 8
8.Question: Is the spray arm split? Yes: Replace spray arm. No: Go to Question 9
9.Question: Is the spray arm running freely? Yes: Go to Question 10. No: Check the rotor is running freely, clear of foreign objects and fitted correctly. Make sure the wash impeller is not slipping off the rotor shaft.
10.Question: Is water leaking from a split inlet or drain hose? Yes: Replace split inlet or drain hose. No: Go to Question 11
11.Question: Is water leaking around the heater plate 'O' rings? Yes: Replace or refit 'O' rings. No: Go to Question 12
12.Question: Is the drain hose blocked? Yes: Clear drain hose of blockage. No:Go to Question 13
13.Question: Is there condensation or foreign matter around the flood switch PCB? Yes: Clear flood sensor of condensation or foreign matter. No: Go to Question 14
14.After clearing water does the F1 fault code still activate? Yes: Replace Chassis RFI board. No: Go to Question 15
15.Refer to Bulletin DW028 DW025, 028, 031, 040
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead,
Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
How do i fix a dd65
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please describe the problem.
