20 Most Recent Liebherr Premium CTP 3153 Top Freezer Refrigerator Questions & Answers
My CTpes 3153 is freezing
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
8/24/2011 1:41:34 AM • Liebherr Premium... • Answered on Aug 24, 2011
What is the recommended freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Leo Ponder
imufo2
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
8/18/2011 4:18:26 PM • Liebherr Premium... • Answered on Aug 18, 2011
Fridge is not cold, light
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Coldheatman101 ................
12/27/2010 10:06:31 PM • Liebherr Premium... • Answered on Dec 27, 2010
I want to install two beer tap faucets in the side of my fridge
All of wires are located in the bottom. The side walls are just filled with foam. HAPPY DRINKING
11/7/2010 1:12:05 AM • Liebherr Premium... • Answered on Nov 07, 2010
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
6/8/2008 1:13:56 PM • Liebherr Premium... • Answered on Jun 08, 2008
The refrigerators accumulate ice
the fridge distrubutes cold by air movement. A overstuffed fridge can have trouble. There is a fan that blows a controlled amount of freezer air over to the food side, altho when this goes you usually have frozen freezer and food too warm. Make sure the air is allowed to move.
1/28/2008 5:45:30 PM • Liebherr Premium... • Answered on Jan 28, 2008
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
1/28/2008 5:40:32 PM • Liebherr Premium... • Answered on Jan 28, 2008
Liebherr fridge model CS1231. How to turn off demo mode on it please?
DemoMode
Liebherr Appliances https://home.liebherr.com > hau > apac > pdf PDF Demo Mode can only be switched off via the service menu, not by pressing ON/OFF nor by disconnecting the appliance from the mains. Once "SuperFrost" has been ... 20 pages
8/7/2023 11:00:09 PM • Liebherr... • Answered on Aug 07, 2023
2answers
Liebherr freezer working, refrigerator doesn't
Take the cover off the fridge fan and put a flash light in there and a camera set to record. close the door for a couple of minutes and then look at the footage to see if the fan is running. The circulation fan should run all the time.
4/5/2023 4:16:50 AM • Liebherr... • Answered on Apr 05, 2023
2answers
LIEBHERR CBNes 39560 Fridge - ice in the drainage trough on the back?
Question edited for correct spelling of the maker. Question moved to maker category. Check the temperature of the fridge with a digital thermometer. I should be 5' centigrade. It may be set too cold and freezing condensation running on the rear wall. Also make sure the circulation fan is working. It looks like it is the round disc at the top rear. Push a flexible net curtain wire down the drain until it appears above the compressor pan. You can also try cleaning the drainage trough, dry it and spray it with dry silicone spray or even WD40 if you don't mind the smell. That will stop water sticking. https://mediamarkt.pl/agd/lodowka-liebherr-cbnes-39560 ..
3/29/2023 5:02:00 PM • Liebherr... • Answered on Mar 29, 2023
Liebherr CUN 3033 The super frost button flashes together with the temperature display. how to reset it?
Resetting your Liebherr CUN 3033 is a fairly simple process. To begin, make sure the appliance is unplugged from the power outlet. Once this is done, press and hold the super frost button for roughly 10 seconds. The appliance should then be reset and ready to use.
1/18/2023 5:44:12 PM • Liebherr... • Answered on Jan 18, 2023
Short power outage confuses Liebherr CbNes 39560 temperature regulation
Unplug it from the mains for 5 minutes to reset the main control board. It is confused by a short disconnect and more confused as it went through its self test procedure. https://www.google.com/search?q=Liebherr+CbNes+39560+reset ..
7/22/2022 1:38:01 PM • Liebherr... • Answered on Jul 22, 2022
Liebherr Premium CTP 3153 Top Freezer Refrigerator Logo
23 questions posted
Top Liebherr Refrigerators Experts
ZJ Limited
ZJ Limited
Paul Carew
Daniel Blask
Daniel Blask
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Liebherr Refrigerators
Most Popular Question
want install two beer tap faucets in
  • Refrigerators
