20 Most Recent
Swift SM95-90HF Stereoscopic Dissecting Microscope (1x & 3x Objective) SM9590HF Microscope Questions & Answers
I have a Swift SM80
Sometimes the eyepiece tubes get out of alignment.
To check for this, look through the microscope. As you are looking through the scope hold the eyepiece tubes and see slightly "flexing" these tubes with your hands has an affect on the image. If your head is the problem you will be able to flex the tubes until the image is clear. You won't need alot of force. Do not use enough force to bend or break the weak metal.
If this works your eyetubes and or head are misaligned.
Unfortunately, once a head has been misaligned like this it is not practically repairable.
Need a reference manual for swift nine fifty microscope
Swift microscopes, as far as i know, don't readily come with a users manual like one would find for a standard home device. Nine fifties are of the simplest microscopes around, any guide to microscopy will do as a user's manual. As for repairs, anyone that is mechanically inclined and with the right tools (allen hex keys, screwdrivers, pliers, lubricant) will be able to fix one after a few minutes of tinkering with it. Don't panic.
It appears that some water
Unfortunately, if you indeed have water or oil inside the lens it is probably ruined. Obviously the seals have deteriorated away. Objectives are practically irreparable. They cannot be disassembled. Very reasonable new and used Replacements are available at:
Delta Optical Instruments, Inc.
Inquire at:
[email protected]
Need a manual
Go on line to the Manufacturer's web site and request an owner's manuel for your microscope!
Are spare objectives & eye
most objectives and eyepieces are interchangeable between models of microscropes. There are however a few things that you need to be aware of. On the out side of the objective there are number written on them that look similiar to this:
100x/1.25
160/0.17
There maybe more writing then that, but usually at the very least you get this. The first part (100x) is the objective magnification, the 1.25 is the Numerical aperture, the 160 is the tube length (in mm), and the .17 is the cover-slip correctness. What you are most concerned with is the mechanical tube length. There are 3 common ones, 160, 210, and infinity. It is very important that you get an objective with the right tube mechanical tube length, or there is a very good chance it won't work. If you are working with slides, then it is a good idea to get one that is cover slip corrected, otherwise most of the other information is only real important to very specific applications.The other key variable is the threading. Most microscopes use what is call a standard RMS threading, however many educational or high end objectives will not have this.
The eyepieces are pretty straight forward. You just need to find one that that has an outside diameter of the sleeve that will fit the inside diameter of the tube it is going into. Beyond that, most eyepieces are pretty interchangeable amongst brands.
I need a light socket and lamp for a Swift Eleven
Carolina Biological sells swift and carries parts for them. If this is not it, http://www.carolina.com/product/swift+upper+illuminator+lamp+m28hfz10.do?keyword=swift&sortby=bestMatches try calling them up and ask them if they have the part.
AA-Spectrometer Unicam 939 Error
The error you are experiencing on your Unicam 939 AA-Spectrometer with the software reporting error 16 and 2, along with lamps 1,2,3,4, and 10 lighting up, could indicate a few different issues. Here are some steps you can take to try to fix the problem:
- Restart the spectrometer: Turn off the spectrometer and unplug it from the power source. Wait a few minutes, then plug it back in and turn it on again. Sometimes, a simple restart can fix issues with the instrument.
- Check the calibration: It is possible that the instrument needs to be calibrated. Follow the manufacturer's instructions for calibrating the spectrometer.
- Check the lamps: If multiple lamps are lighting up, it could be due to a problem with the lamp assembly. Check that the lamps are properly installed and functioning. Try replacing any lamps that appear damaged or worn.
- Check the power supply: Make sure the power supply is functioning properly by testing the voltage output with a multimeter. If the voltage output is incorrect, try replacing the power supply.
- Check the communication between the software and the spectrometer: Ensure that the software is properly communicating with the spectrometer. Check that the cables are properly connected and that the software settings are correct.
If these steps do not resolve the issue, it may be necessary to contact the manufacturer for additional support or to seek the assistance of a professional repair technician.
3/24/2023 6:39:35 AM •
Science &...
Answered
on Mar 24, 2023
Eppendorf centrifuge model 5702: lid not does latch/lock after emergency release.
If the lid of your Eppendorf centrifuge model 5702 is not latching or locking closed after the emergency release, it is possible that the locking mechanism is damaged or misaligned. Here are some steps you can try to troubleshoot the issue:
- Check the alignment of the lid: Make sure that the lid is properly aligned with the base of the centrifuge. If it is not, the locking mechanism may not engage correctly. Adjust the lid as needed and try to latch it closed.
- Inspect the locking mechanism: Check the locking mechanism on both the lid and the base of the centrifuge for any signs of damage or wear. If you see any damage, you may need to replace the locking mechanism.
- Check the safety interlock switch: The safety interlock switch is a small button located on the base of the centrifuge that is depressed when the lid is closed. If this switch is not working correctly, it can prevent the lid from latching closed. Check that the switch is functioning properly by pressing it with a small tool while attempting to latch the lid.
- Contact Eppendorf customer support: If none of the above steps work, you may need to contact Eppendorf customer support for further assistance. They can help you troubleshoot the issue and provide advice on how to proceed.
3/15/2023 4:55:19 AM •
Science &...
Answered
on Mar 15, 2023
