20 Most Recent
Beverage-Air Freezer K Series Reach in Freezer 2 section 449 cuft Questions & Answers
Beeping freezer??
Also check that there is plenty of room around the air vent to stop the freezer overheating.
Thanks J
Freezer water line frozen
Sounds like your defrost sensor is not working the sensor should return the fan running and cooling after it senses 50 degrees in the condensor housing unplug the sensor and check if it shows a closed circuit. First unplug the freezer for your safety
Let us know what you find.
What are the minimum and
Most all manufacturers try to build units to hold between 34 to 38 degrees as this is the most commonly accepted range for coolers by all Health Departments.
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words.
That is an overheating fault. Replace the fluff with no fluff.
Make sure the condenser coils are free of dust and there is good airflow
Or
It is low on refrigerant gas and you need a service tech..
2/3/2024 5:25:13 AM •
Freezers
Answered
on Feb 03, 2024
