20 Most Recent Ariston Technologies AW125NA 13 lbs. Load Capacity Washer Questions & Answers
2answers
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
3/16/2020 7:30:19 AM • Ariston... • Answered on Mar 16, 2020
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
9/22/2018 3:52:01 AM • Ariston... • Answered on Sep 22, 2018
Error code F-05
F05 - Pressure switch jammed on full
12/21/2015 7:53:51 AM • Ariston... • Answered on Dec 21, 2015
Fabric Softener Does Not Drain
25569074-ineink0kisfnom0atbkujjcx-3-0.jpg compartment 1: Detergent for pre-wash (powder) Before pouring in the detergent, make sure that extra compartment 4 has been removed. compartment 2: Detergent for the wash cycle (powder or liquid) Liquid detergent should only be poured in immediately prior to the wash cycle start. compartment 3: Additives (fabric softeners, etc.) The fabric softener should not overflow from the grid. extra compartment 4: Bleach ! Do not use Hand Wash Detergent because it may form too much foam. Cleaning the detergent dispenser Remove the dispenser by raising it and pulling it out (see figure). Wash it under running water; this operation should be repeated frequently. 25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg Dado
10/28/2015 7:46:15 PM • Ariston... • Answered on Oct 28, 2015
Error code 1
F01: Triac Short circuit Overhaul CNE Replace Card Dado
10/6/2015 6:41:48 PM • Ariston... • Answered on Oct 06, 2015
Ariston washing 125 is flushing h2o on the screen
The washing machine fails to load water (The wording H20 is displayed). • The water inlet hose is not connected to the tap. • The hose is bent. • The water tap is not turned on. • There is a water shortage. • The water pressure is insufficient. • The START/RESET button has not been pressed. Dado
10/6/2015 6:29:34 PM • Ariston... • Answered on Oct 06, 2015
My ariston 125washing machine is flushing H2O on the scrim
10/6/2015 6:28:38 PM • Ariston... • Answered on Oct 06, 2015
0answers
Why when I put the washing in 30 min wash the manching is flushing h2o
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot.
6/2/2014 3:47:01 AM • Ariston... • Answered on Jun 02, 2014
0answers
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
4/13/2014 7:35:49 AM • Ariston... • Answered on Apr 13, 2014
Waring diagram problem
if the display/diagram is digital it may need the fuse changing?
3/14/2013 10:27:16 AM • Ariston... • Answered on Mar 14, 2013
0answers
Washing Machines Logo
84 questions posted
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Ariston Technologies Washing Machines
Most Popular Question
ariston washing 125 show h2o scrim
  • Washing Machines
