20 Most Recent
Maxent MX-50X3 50 in. HD-Ready Plasma Television Questions & Answers
How do I connect the coax antenna cable?
This unit doesn't have a tuner, This is what I found when researching this question for you.Maybe you can hookup DVD player or VCR player with audio and video cables, I know some VCR's have HDMI on them too that can be hooked on that TV. Good Luck
Why power light is blinking
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in '
Mosaic' view. It will make search easy.
HDMI input blown, no HDMI
we have to unplug the hdmi cord at the cable box and plug back in . Try it, I just figured my set is on it's last leg
My Maxent mx-50x3 has a intermitten problem, when
i had the similar problem. i'm not a tech but like to take stuff apart to find the problem. on my tv i took the back completely off. do not touch the boards. if you follow the power supply from the plug up two boards i found a small white adjustment screw. it was just up and to the right slightly from the plug. with a small screw driver i turned it slightly to the right and the flickering and delayed picture went away. couldn't tell you why it worked but it did. hope this helps, saved us $800 to buy a new tv.
