20 Most Recent Hoover AL130 Front Load Washer Questions & Answers
0answers
0answers
Hoover hnl842
Be the first to answer 6/30/2012 4:07:45 AM • Hoover AL130... • Posted on Jun 30, 2012Be the first to answer
There is no water flowing to to be washed
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
10/7/2011 7:28:47 PM • Hoover AL130... • Answered on Oct 07, 2011
I have a hover 6
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
John C
7/9/2011 8:13:37 AM • Hoover AL130... • Answered on Jul 09, 2011
TROUBLE CHANGING BEARINGS, DUE TO BEARING SHaft
You will have to remove the complete drum and shaft assy from the washer to change the bearing/s, there is no other way of doing it unfortunately.
10/12/2010 9:41:26 PM • Hoover AL130... • Answered on Oct 12, 2010
The hoover al 130 wasing
http://www.hoover.com/CustomerService.aspx
Please find above your customer service link for your manufacturer, there too you can get any manuals, if you wish to know more.
or, translated as... Xtra Large Wash? Xtra Large Load. XL being international, "Speak" for Xtra Large.
That flashing LED, usually indicates a controller failure. If you look inside the inspection hatch, there should be a maintenance sheet, this will allow you to troubleshoot if you wish to DIY. As one still must troubleshoot to isolate the exact problem.
However, I think professionally that it would be more expedient and actually less expensive if you got the unit looked at by a Serviceman.
9/5/2010 4:33:18 PM • Hoover AL130... • Answered on Sep 05, 2010
High vibration front loader
have u checked the bearings to do this u open the door place your palm on the front of the face panel and place your fingers on the inside of the drum and grab the inner drum and move your fingers towards your palm if there is movement then the bearings are gone and need replacing if there isnt then it could be the springs that are placed under the top they could be broken if not then replace your damper legs they may look ok but they will be down on pressure m
3/5/2009 9:14:04 AM • Hoover AL130... • Answered on Mar 05, 2009
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
9/17/2008 10:02:14 AM • Hoover AL130... • Answered on Sep 17, 2008
Not heating cold water
this could be 2 possible symptoms 1 the thermostat which gets the heater element to work. 2 it is the heating element that is faulty if the element has gone then this is about £15 to buy which u get both thermostats which u might has well replace both at the same time now if its the heater element then this will be around £20-25 to replace now my best suggestion is call out an engineer that doesnt charge any call out fee this will tell u exactly which if these it is if its thermostat then do it yourself easy job which will only take u around 30 minutes to do from start to finish if its the heater element then get them to do it which should cost around £65 to do this is because it needs to be sealed properly otherwise it will leak and cause more problems in the long run
7/21/2008 11:52:01 PM • Hoover AL130... • Answered on Jul 21, 2008
Hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
4/15/2008 1:23:13 PM • Hoover AL130... • Answered on Apr 15, 2008
MAchine Boils the water
if the temp sensor is operating ok but the element doesnt switch off there may be a problem with the power board/timer just follow the wires back to find problem.
3/4/2008 9:30:08 AM • Hoover AL130... • Answered on Mar 04, 2008
Instruction Manual
1/26/2008 6:20:24 AM • Hoover AL130... • Answered on Jan 26, 2008
Drum Bearing Replacement
With a plastic tub (outer drum as you describe it) removal of the old bearings can deform or bruise out the plastic housing a little - you will need to check that the new bearings will be really good fit. You may need to use a retaining compound if not, to ensure that the outer journals of the bearings don't creeping round in the plastic housing and wear it looser.
I did my Hoover Electron 800 bearings (metal tub). As i recall it was fairly straightforward - needed a gasket for the tub backplate on that.
Unbolted tub backplate from tub and withdrew it through rear of chassis along with drum/drum-shaft/bearings assembly, removed pulley, tapped shaft through bearings with softfaced mallet (or hammer & wood), drifted bearings out gently, working evenly around circumference.
For plastic tub some kind of suitable extractor may reduce chances of deforming bearing housing during bearing removal, compared to drifting them out. If it'd serve to ease the new ones in too then that'd be even better.
Don't forget to check/clean the water level pressure sensor path while you're at it - stave off any problems in that area for a while while you have the machine apart. ;o)
1/4/2008 1:05:19 PM • Hoover AL130... • Answered on Jan 04, 2008
Water won't stop heating up
You should replace the thermostat (it doesn't stop current to the heating element in the temp it should). Good luck!
9/4/2007 12:54:50 PM • Hoover AL130... • Answered on Sep 04, 2007
Rinse problem
the motor operated cam within the timer is worn. plan to spend about $120 for a new timer
8/23/2007 12:20:27 PM • Hoover AL130... • Answered on Aug 23, 2007
Hoover washing machine shows lock symbol and won't start
How can I turn the red lock symbol off on my Hoover? Washing machine 300 light.
1/25/2024 4:59:19 PM • Hoover Washing... • Answered on Jan 25, 2024
2answers
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
12/7/2023 5:47:52 PM • Hoover Washing... • Answered on Dec 07, 2023
My Hoover WDYNS 654D-80 washing machine now displays E05 error. Please what is he possible fault and how can i fix it?
Hello, check youtube link or search for Hoover e05 error. I hope to be usefull. All the best !
9/9/2023 7:40:01 PM • Hoover Washing... • Answered on Sep 09, 2023
Hoover AL130 Front Load Washer Logo
32 questions posted
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
hover 6
  • Washing Machines
