20 Most Recent Hoover AAA160 Front Load Washer Questions & Answers
Hoover Nextra No Lights Not working
please check the fuse in the plug it should be13 amp it has no doubt blown after replacing it and happens again there might be a problem with the heating element it might be faulty or ruptured due to short circuit in the element eric
12/25/2017 9:19:36 PM • Hoover AAA160... • Answered on Dec 25, 2017
0answers
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle yes it can be replaced, take photo and model number of machine order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
10/5/2016 9:17:32 PM • Hoover AAA160... • Answered on Oct 05, 2016
Why my hoover is not drying very well its an automatic machine
Make sure the drain line isn't clogged with a sock or something small. Some models have a lint trap, usually at the front, that requires periodic cleaning. If the trap or drain line is partially obstructed, a first load's rinse water won't drain completely in the lowest part of the vertical drum you can't see. If this doesn't solve your issue, there is a pump problem.
4/9/2015 4:14:26 PM • Hoover AAA160... • Answered on Apr 09, 2015
0answers
2answers
Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
11/5/2014 8:07:14 PM • Hoover AAA160... • Answered on Nov 05, 2014
0answers
0answers
0answers
Hoover oph 614 on the front at the bottom ther is
Had the same problem today. Found a very small piece of lint/fluff in the sealing groove of the filter socket. Removed this with an orange stick & touch wood the floor is dry again.
Do hope this helps
2/12/2014 4:40:17 PM • Hoover AAA160... • Answered on Feb 12, 2014
0answers
0answers
Hoover AAA160 Front Load Washer Logo
155 questions posted
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
lock hoover nextra front loader washing
  • Washing Machines
